Cylinder extension
/ Cylinder extension #1
rmully
Gold Member
North Carolina
YM 2020
I have a cylinder that is 36" from center of hole to center of hole while closed... I am trying to figure out what will be the length when extended fully. Can I put air in the cylinder to extend it? This is all new to me and I am trying to make a log splitter. Any formulas.... The label on the cylinder was rubbed off but I know it is a Chief.
/ Cylinder extension #2
Don't use air!!!!!!!! If you can't pull it open by hand you could use your tractor. Go slow.
Thanks ... I have a come-along that I will try.
/ Cylinder extension #4
I have used air many times, but you must be prepared for it to open quickly and have the body of the cylinder secured.
/ Cylinder extension #5
May I ask what's the reason for not utilizing air to extend the cylinder? There are air operated cylinders being used.
/ Cylinder extension #6
A lot of hyd cylinders are marked with their diameter & stroke.
/ Cylinder extension #7
I have used air also alot of times, but I didn't like telling someone to use it and getting hurt.
/ Cylinder extension #8
put in vise , put a rod thru the eye, pull and twist at the same time .....
low pressure air works well , but can extend the rod quickly ...
2022 EZ-GO ELITE...
2018 John Deere 3025E (A64126)
2018 John Deere...
2006 Peterbilt 379 T/A Sleeper Cab Truck Tractor (A64194)
2006 Peterbilt 379...
Wooden Rocking Chair (A64127)
Wooden Rocking...
2008 Ledwell LW48HTHT2 48ft. 40 Ton Hydratail T/A Step Deck Trailer (A64194)
2008 Ledwell...
2004 Chevrolet Silverado 1500 Pickup Truck (A64556)
2004 Chevrolet...
