Cylinder extension
/ Cylinder extension #1
rmully
Gold Member
North Carolina
YM 2020
I have a cylinder that is 36" from center of hole to center of hole while closed... I am trying to figure out what will be the length when extended fully. Can I put air in the cylinder to extend it? This is all new to me and I am trying to make a log splitter. Any formulas.... The label on the cylinder was rubbed off but I know it is a Chief.
/ Cylinder extension #2
Don't use air!!!!!!!! If you can't pull it open by hand you could use your tractor. Go slow.
Thanks ... I have a come-along that I will try.
/ Cylinder extension #4
I have used air many times, but you must be prepared for it to open quickly and have the body of the cylinder secured.
/ Cylinder extension #5
May I ask what's the reason for not utilizing air to extend the cylinder? There are air operated cylinders being used.
/ Cylinder extension #6
A lot of hyd cylinders are marked with their diameter & stroke.
/ Cylinder extension #7
I have used air also alot of times, but I didn't like telling someone to use it and getting hurt.
/ Cylinder extension #8
put in vise , put a rod thru the eye, pull and twist at the same time .....
low pressure air works well , but can extend the rod quickly ...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
(2) Firestone Tires (A65640)
(2) Firestone...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
Allis Chalmers WD45 (A66285)
Allis Chalmers...
