Mahindra Three Point Hydraulic Problem
/ Mahindra Three Point Hydraulic Problem #1
smstroble
Valley Mills, TX
2006 Mahindra 5500
I have a 2006 Mahindra 5500. I have been using a box blade connected to the three point hook-up, Recently when the blade would strike something, the blade would go up. Now it will not go back down. Does anyone know what this could be or how to correct the problem?
I just checked the manual and it does have draft control
/ Mahindra Three Point Hydraulic Problem #5
I"d suggest that you post a thread in the Mahindra owner operator forum probably find more info there. a draft will cause it to raise when pulling hard or hit something. But it should go back down . work levers up and down to see if this makes a difference.
/ Mahindra Three Point Hydraulic Problem #6
There should be 2 levers. Based on my 7520, the draft control lever should be pushed all the way forward to disable the DF function. That hopefully will restore normal operation.
larry
Kubota Pull-Behind Spreader Tractor Attachment (A61572)
Kubota Pull-Behind...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
UNUSED SDLANCH HYD DUMPER (A64280)
UNUSED SDLANCH HYD...
2018 Isuzu FTR Landscape Dump Truck (A61573)
2018 Isuzu FTR...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
