Quick Attach Conversion Kit.... Need a little help
/ Quick Attach Conversion Kit.... Need a little help #41
Thanks Xfaxman, but I was referring to the spring that is holding the handle down, not the one attached to the pin that secures the implement. I have not fit it to an implement yet to check the fit there.
/ Quick Attach Conversion Kit.... Need a little help #42
You don't need much spring tension on the handle. What keeps it down is the compression on the lower spring when it hits the attachment plate, and the handle keeps moving until it hits the stop, (usually adjustable) just over center. That lower spring is holding the pin tight against the QA plate.
The distance the pin goes down varies on different plates, depending on wear in the slot.
To raise the handle, you have to compress the lower spring a little as the linkage comes back over center and pulls the pin up to unlatch the attachment.
Compare this handle to yours, notice how it has been ground off to provide the over center stop when it is fully down as in their picture.
/ Quick Attach Conversion Kit.... Need a little help #43
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=302978"/>
Thanks for the info, especially the part about the ground handle - I had not seen that before. I will keep that in mind when placing the stop on mine since I am not putting on ears there.
/ Quick Attach Conversion Kit.... Need a little help #44
The total width is 49" and each of the plates are 7" wide and 22" tall. These plates will be wider on future editions when we run this in full production in 60-90 days.
Are these in production yet?? Can I get it in John Deere green? LMK, ready to buy!
/ Quick Attach Conversion Kit.... Need a little help #46
/ Quick Attach Conversion Kit.... Need a little help #47
In production yet?? What size did the 7" x 22" plates change to? John Deere Green?
We recently received new stock of the Quick Tach Assembly. The plates are now 12" x 22", and are painted red. Don't hesitate to let us know if you would like one, as they're moving quickly.
/ Quick Attach Conversion Kit.... Need a little help #49
The china container must've arrived finally!
/ Quick Attach Conversion Kit.... Need a little help #50
Don't be so quick to assume, according to SkidsteerExpress/Palletfork.com most of there items are made in Memphis, TN. Now could this one be from somewhere else I don't know, but you could ask them if you really wanted to know.
/ Quick Attach Conversion Kit.... Need a little help #51
Placed my order today.
/ Quick Attach Conversion Kit.... Need a little help #52
So, what kind of results are people finding in real life testing.
I have a Foton 704 with a spirit implements front end loader and I am in need of installing a quick hitch adapter.
Are these holding up well. It looks like exactly what I need.
Joe
/ Quick Attach Conversion Kit.... Need a little help #53
We just finished making a new Quick Tach Conversion kit to convert pin on style loaders to the skid steer/tractor style universal quick tach hookup. The cost for the kit will be $259(free shipping) and it includes a mounting plate and both quick tach brackets.
We need step by step photos of an install of this kit for our ads. If you have the ability to cut, weld and email good photos we will sell you the kit for $100 in return for some good photos. Inbox us for details or email us at info@palletforks.com.
Thanks in advance for the help and we hope everyone is having a great weekend!
Bill
Skid Steer Attachments Pallet Forks Hay Spears Bobcat Cat John Deere Mount Plate
www.palletforks.com
View attachment 300984View attachment 300985View attachment 300986
Maybe this was covered in a earlier post.
I used your latch plates for my build and they work great but you cant just cut off your brackets and weld directly to the plate like the picture in post #1 shows , even if the width allows it the kickouts where the pins latch in hit the loader arms and prevented the bucket from pivoting to full dump. Just want folks to check there clearance ahead of time when fabbing things up. I ended up with a 2" piece of square tube as a spacer under my pin boxes which was perfect.
If I was to do it over i would just cut the pin boxes "out" of the bucket and not "try" to cut them "off" of the bucket then use the 2 rectangle holes in the bucket for some extra weld on the backing plate.
/ Quick Attach Conversion Kit.... Need a little help #54
I was searching the net looking for build log that used the titan latch plates and came across this thread. Did anyone end up creating a build log for these? I ended up keeping one as I went, available here:
Shop Stuff
/ Quick Attach Conversion Kit.... Need a little help #55
Shop Stuff
Nice job and the conversion and you did a good job documenting it.
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
(2) HARROW DRAGS FOR WINGS (A63291)
(2) HARROW DRAGS...
UNUSED ATSPOWER PROPANE PATIO HEATER (A64281)
UNUSED ATSPOWER...
2017 Buick Encore Preferred SUV (A61574)
2017 Buick Encore...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
