sub-soil rippers
/ sub-soil rippers #1
Gary Fowler
Super Star Member
Bismarck Arkansas
2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I have been using my box blade rippers to dig up some rocks but I just cant get them in the ground deep enough. I was driving past a local hardware store who also sells a few implements and they had what looked like the front ripper side of a 5 foot box blade for sale for $300. I just had to buy one to try it out. I will unhook my box blade and try it for digging those pesky rocks out. Likely I could have searched and found a box blade and modified it for same or less money, but I have this now and no further work needed.
I may later get some heavy steel and make a 3 PH attachment so I can hang this on behind my box blade for a double whammy at those rocks.
Anyone ever use one of these attachments.
/ sub-soil rippers #2
One of this style?
Rankin scarifier
Often the hitch pins are higher so it will go deeper than a box blade, even without taking into consideration the blade behind interfering.
Bruce
/ sub-soil rippers #3
Could you have used only 2 rippers? or even just one? vs. using 4 or 5 on the box blade???
/ sub-soil rippers #5
One of this style?
Rankin scarifier
Bruce
It sounds to me like there is not enough weight on the shanks. I used my 700# ROBB to do the same in my heavy clay soil and the ROBB's weight was just barely adequate. A 1000# - 1500# box blade would have been better.
/ sub-soil rippers #7
I've used the rippers on my roll over box blade and on my LPGS. Either one pulls up lots of rocks. As a matter of fact, I'm still "gathering" rocks from a three acre patch I ripped. I don't need to go deeper - I get more than I like with either of the two implements. I go as deep as I can - to the point where the tractor looses traction and begins spinning. I think a two or three tine scarifier would go deeper but it might also hook onto the core of the earth and suck me down.
Man, I REALLY don't need to bring up more rocks!! I need a pto driven rock crusher to create more soil.
/ sub-soil rippers
/ sub-soil rippers #9
+1, +2, +3
/ sub-soil rippers
I wanted to get as many of the deeper rocks as I could so they don't continually push up from winter freeze cycle. I made a run this morning at picking up what I turned up yesterday and got about 2/3 of an RTV box load. I will surely find some more small ones when I till, but I am pretty sure I got 99% or the ones that caused my tiller to bounce off the ground.
/ sub-soil rippers #11
/ sub-soil rippers
It wasn't that the box blade rippers wouldn't go in the ground, the rippers kind of pull themselves into the ground You just cant tilt a box blade but so much before you run out of top link threads. If you shorten the top link too much, the box blade will flip over when it gets enough pressure to compress the linkage to the draft control a bit, BTDT. I have my top link within about an inch of screwed in completely. The most I could get was maybe half the shank in the ground and then the back of the box blade starts to drag also.
When I put on the new ripper, the first pass it went almost to the beam. The next pass I noticed the lift control arm wasn't down all the way, so I lowered it a bit more and then beam was dragging the ground. A couple of spots with very hard compacted clay soil, it stalled the tractor (wheel slippage) so I had to raise it, backup and hit it again to bust thru. The Cat 1 ripper handled all the Cat 2 tractor wanted to give.
I will try to get a photo of it to post.
/ sub-soil rippers
/ sub-soil rippers #15
I would love to have the soil type something like that would dig in, but I am sure it would just skip across the top of my very hard clay/rock "soil". To understand what I deal with, imagine someone mixing up a few billion cubic yards of expansive clay with rocks from fist size to small boulder size and then pouring the mix onto the bedrock, and you have my property. There is no just removing the surface rocks and immediate subsurface as it is rocks all of the way through.
Here is my Fred Cain subsoiler, same one ETA is using in their videos. It is unused so far as I do not have the heart to even hook it up yet. I have to clear 1.5 acres of dense trees for the home site (less rocky area) and will use the subsoiler to rip through some of the stump roots to make it easier to remove the smaller stumps. Then will have a mini-x dig out the larger stumps.
/ sub-soil rippers
/ sub-soil rippers #17
Yes a Yeomans plough is a great subsoiler but it's an expensive piece of gear that I wouldn't recommended solely for ripping out rocks
Ripping out rocks is something that usually occurs with subsoiling or chisel ploughing, regardless of whether you want to rip them out or not.
The yeomans plows main function is that of a subsoiling, but if you take a look at photos of some of the country that it has developed rocks do not present a problem.
Looking at some of the machines shown on this thread I would say that they appear to light for working in rocky going.
/ sub-soil rippers
In some of my super hard clay areas, it digs in and stalls the tractor if I let it down all the way in one pass. This thing has no problem digging in even the hardest soil. I think you have to set the top link right for it to dig in. As seen in the photos, my attachment frame is level so the teeth set at a natural incline to dig in rather than skim along. Kind of like setting the angle on a straight blade for digging or skimming.
Your Fred Cain sub-soiler would be best for cutting roots. Maybe sharpen the leading edge so it cuts thru easier. I don't think your DK45 would have the power to pull this 5 plow ripper especially in roots or super hard soil. Maybe going multiple passes and working it down a little at a time would work. Even with fully ballasted tires, I run out of traction with my P7010 when I hit my hard clay soil area.
/ sub-soil rippers #19
Gary, that would come in handy for aerating and draining a wet area caused by soil that has become compacted over the years.
I could use one of those myself. I have a spot in my pasture that stays wet for a few days after a rain.
/ sub-soil rippers #20
Agreed a Yeomans plough & most subsoilers can handle rocky country, but they're are an expensive & poor substitute for dedicated rippers - we operate a lot of gear including these implements & I wouldn't recommending using a yeomans to clear or break rocks (no unless you have $'s to burn), far cheaper & productive to use something designed for the tasks like these rippers to surface the rocks followed by a crusher to break them up :
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Loader Bucket (A68183)
Pemberton Inc...
2021 CATERPILLAR 420XE HRC BACKHOE (A65056)
2021 CATERPILLAR...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2018 Hitachi ZX300LC-6N Hydraulic Excavator (A66734)
2018 Hitachi...
2022 WESTERNSTAR 4700 CONCRETE MIXER (A67714)
2022 WESTERNSTAR...
