8FT VS 10 MX
/ 8FT VS 10 MX #22
It sounds as if you will have plenty of power to use the MX-10 with the 5085 as long as you not cutting unusually tall or thick grass (5-6ft high) and don't want to drive 5-6 mph.
I use a 5075 with a MX-8, and I think its a great match. I have roughly 10 fewer hp at the pto than you. In fact, I think my 5075 would handle the MX-10 just fine in all but the toughest conditions.
You may also want to consider how many acres you are cutting. For example, you will not see a large reduction in cutting time if you are cutting 5 acres, but you will see a significant reduction if you are cutting 25+ acres.
/ 8FT VS 10 MX #23
I just sold my 8ft and bought a 15ft batwing,both LandPride purchased the Plainsman for 11,600. I have it set at 6in.cutting height and with 64pto HP i was running 4low at 4.2mph,without any problem. I also have a 12ft straight deck Woods brand shredder,good for level pastures only but the cut quality on all three are the same,all do a great job. Have you looked at the 12ft batwings also,they are alittle better $, I have also seen some of the lighter duty 15ft for around 9,000.
/ 8FT VS 10 MX #24
Sorry about pictures being sideways and upside down,it's me and this new phone. I have it figured out now,some what...
/ 8FT VS 10 MX
I am mowing about 50 acres... few obstacles and rolling hills. Takes me about 7 hours give or take to mow, but I am limited on time with the work schedule I have. So, if I can safe 1-2 hours that would be amazing to me. We have a baby coming so I can't really afford to drop $7,000 toward my trade in for a 15ft MX. I can afford the extra $2,000 on the MX10. What is funny is that at the time while purchasing I could have had the 10FT for the same price as the 8FT. :)
/ 8FT VS 10 MX #27
WHo talked you out of the 10? and what was their reason?
/ 8FT VS 10 MX #28
How do you justify the cost of mowing 50 acres? No horses, cattle, or something to graze that much area? Just curious.
/ 8FT VS 10 MX
I have no cattle, nor horses or any live stock for that matter. I talked myself out of getting the 10fter and wished I would have went with it from the start. I have 50 acres to mow so time is an issue, considering my work hours and time that I have available.
@beenthere - How do I justify mowing 50 acres of land? Well.... because it's mine ;) ... I had several hundred head of cattle at one time (not on this land) and sold out. I just don't have the time to work the cattle and to be honest, cattle makes a mess on the land from destroying the ponds to other things. I love the look of having open land that is green as a golf course and next year I plan to hay the fields or something.
Right now I am working hard to get the land in great condition and conditioned.
@trook - I almost went the the 75 just like yours. Super nice tractor. A friend of mine has the same one you have, the 5075E.
/ 8FT VS 10 MX #31
Don't need any more justification than that satisfaction.. :thumbsup:
I do too, but it's 6-8 acres. ;) And as long as you can afford it, go for it.
/ 8FT VS 10 MX #32
Double posted for me too. What's up?
/ 8FT VS 10 MX #33
You don't have 85 hp. They advertise 85 hp but you really have around 70 use able (Read: At the PTO). I have the older brother the 5083E with an MX10. In heavy cutting, I have just enough hp to run at around 4 mph. I'm talking grass as high as the front tires. If your clipping a pasture, sure. 15 footer would be a great addition.
Ditto.
/ 8FT VS 10 MX #34
70 PTO HP is more than enough for a 10 foot cutter.
I've pulled a Bush Hog 3210 a few times with a 45 HP tractor though knee high weeds and it didn't even phase it at 6 mph.
I beg to differ from my personal experience. I have 70 PTO HP and pull the MX10 and I wish I had more horsepower at times. When I get into thick grass or start chopping up some overgrown bushes, Even at 4mph I have to slow down to keep the tractor from bogging down to badly. Grass maybe a little bit thicker up north my way? If I get into a large ant hill or an uneven patch where I start mowing dirt, it really bogs the tractor down. Open fields, as long as I can stay in the seat, I can mow it.
The 5085E has enough HP to mow with the MX10, if you are keeping up with your mowing (more than once or twice a year) then I don't see any problem with a 15 footer especially if your mowing 50 acres!
/ 8FT VS 10 MX #35
I suppose its varies.
In my experience I definitely can be underpowered running a 10 footer with only 45 PTO, but I've yet to be underpowered with a 10 footer and 70 PTO. Then again I have certain "rules" so to speak on how I mow and what speed and height to cut at.
I mow a lot of orchards where the grass rarely gets more than a foot tall before it is mowed again, so even a 40-50 PTO tractor can handle a 10-15 cutter with ease at 5-7 MPH.
When I have to mow thick and stall stuff I go really slow. Usually 2-3MPH. In that case I often can be underpowered with 40-50PTO but rarely with 70PTO.
/ 8FT VS 10 MX #36
You can have 200hp and still find times to BG a 10’ cutter.
The only time I'll agree that your cutter is too big, is when you bog and stall in your lowest gear.
/ 8FT VS 10 MX
THANKS everyone for the help and feedback. I'll let everyone know what I decide to do over the next couple weeks. Summer is winding down and I won't have to mow as much, so I have to figure if now is a better time to trade considering my MX8 is brand new.
/ 8FT VS 10 MX #38
I just ordered a 5085e. I think the mx 10 looks perfect for it. I mow 28 acres not including roads etc. I think the mx10 would be perfect for me. In your case an mx 10 or 12 batwing would be perfect.
/ 8FT VS 10 MX #39
Just remember that your going to need some front end weight with the MX10, I run with the loader on the majority of the time and I won't even attempt it without 4 suitcase weights on the front end.
/ 8FT VS 10 MX #40
... I'll let everyone know what I decide to do over the next couple weeks ...
So did you upgrade ?
I sold my MX6 & wanting a MX10 for my 5093E.
2018 JOHN DEERE 331G SKID STEER (A65056)
2018 JOHN DEERE...
Set of 4 Unused 12-16.5N.H.S. ForeRunner Skid Steer Wheels and Tires (A66734)
Set of 4 Unused...
2005 Infiniti FX35 AWD SUV (A66738)
2005 Infiniti FX35...
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
2007 Mack CHN613 T/A Day Cab Truck Tractor (A66736)
2007 Mack CHN613...
CRATE OF MISC ELECTRICAL WIRING (A67714)
CRATE OF MISC...
