He described a case where an owner with a Cat. 2 hydraulic top link was carrying
his big rotary cutter in the fully raised position. He went over some hummocks too fast, causing the cutter to
bounce up and down so violently that the cylinder was seriously damaged.
I believe you can damage a HTL that way. My tractors all have a shock-RVs in the 3-pt cylinder ckt to avoid
such damage to a fairly robust 3PT cylinder. It is set to almost 3000psi on my Kioti. Driving any tractor
fast (over 10MPH) on less-than-smooth roads can put huge tension stresses on the HTL cyl, too. I would
not be as concerned about sideways stresses to the HTL since they have Heim joints at both ends. To
avoid these stresses to the HTL, drive slower, put a workport RV in the system, or buy a larger diameter
HTL cylinder.
Threaded OEM toplinks have all been pretty wimpy, in my experience. The many rental tractors I have
owned always had somewhat buckled threaded toplinks from aggressive box blade use. The $25
threaded aftermarket toplinks I have bought have all been stouter than the OEM units.
I love hydraulic toplinks, and the downsides are few. I did prefer my 2nd one, which I made to a
custom length, versus the off-the-shelf unit (my first one). Customizing the open and closed
length to your tractor and implements is nice.
