Rhino coating mower deck
/ Rhino coating mower deck #1
xtruckerbob
Louisiana
Kubota BX 25D, Kubota Bx 2670, Kubota RTV, 900, Kubota L-2600, Kubota G-3200, Kubota Z121S, John Deere L-160
I have heard people talk about Rhino Coating the underside of a mower deck. I am wondering if any one has tried it and if so does the grass bald up under the deck or does it still flow out smooth? Wish I had tried this on my bush hog as it has rusted though in 10 tears.:confused:
/ Rhino coating mower deck #2
The grass would build up easier with the coating...causing more problems than it's worth. The coating has a bit of a tacky surface, not slippery or smooth. Cleaning off the grass from the underside should eliminate most of the rusting problems. After cleaning, make sure to look for any bare spots and touch them up with some regular paint.
/ Rhino coating mower deck #3
Yeah, I would think if you coated it with anything it would be Teflon. Or, maybe whatever non-stick surface they use on pots & pans.
/ Rhino coating mower deck #4
Blast to white metal and coat with a two part epoxy coating.
You could use some Enecon metalclad, but it is expensive. Probably need two or three kits for a 6 foot mower. About $400/kit.
/ Rhino coating mower deck #5
I agree. And the coating would eventually peel off in places, thus exposing bare metal again and it would be a mess.
There's probably a very good reason why none of the mower manufacturers offer this as an option or upgrade - because it would be counterproductive.
/ Rhino coating mower deck #6
I have used Rhino Coatings twice and were very unhappy with the product.
Line-X I have used 4 times now and very pleased with it.
I have also used Rustoleum to which I will reserve my opinion a few more months before giving feedback on that.
Thanks guys, Well trying to get ahead of the game. We mow about 10 acres a week 1/2 with a 5 ft Land Pride finishing mower behind a L 2600 and 1/2 with a BX 2670 with 5 ft finishing mower (my wife's). I use a high pressure wash every 2 weeks then re grease. Some of the grass my wife cuts is like a "water grass" and it packs under the deck bad ... no wait it packs solid.
/ Rhino coating mower deck #8
In Florida we have a problem with sand eating up the decks I talked to a man who is in lawn care business runs three crews. He takes every new mower deck and scuffs paint and sprays bedliner on them he says he gets double or more of life out of them might not apply to all areas but he says it works here great mowing
/ Rhino coating mower deck #9
Have you considered a flail mower for the areas your wife mows?
/ Rhino coating mower deck #10
IT sounds like if the grass it growing that fast, you need to mow more often and not let it get so tall. Clogging under the deck is sign of mowing wet or too tall. I would mow it down about half of what you normally cut then come back in 2-3 days and cut it down about 30% of the standing height that is left. This should do much better about the clogging. After you get it to a manageable height, cut it again whenever it grows not more than 3" above the just mown height (whatever that frequency might be).
/ Rhino coating mower deck #11
1st of all, let me "Thank you for your service to our country".
You could try what I do each year. I, like you, wash under all my mower decks every other time I mow. When I'm done in the fall, I remove the decks, take off the blades for sharpening, pressure wash them, then give them 2 coats of fresh paint (High gloss enamel). When the paint is dry I put the blades back on and remount the decks on all but the BX 2350. No need to have deck on tractor for moving SNOW ! ! ! :laughing:
Best of luck with your decks.
Dave
/ Rhino coating mower deck #12
I just bought a used snow blower that needs paint. We've been using PPG AUE-370 (a catalyzed coating) on some things at work and it looks promising. I've been thinking of doing the underside of the deck while I'm at it. They do have a formula for Kubota Orange.
GMAN BART She would not use it she loves that belly mower.
Gary, we mower at least once a week with out fail. The grass does grow fast because we put out 13 13 13 every year, plus we have had a very rainy summer. The grass is reclaimed pasture which was re-seeded with Bermuda grass but still has some "water grass" which is always wet no matter what time of day. The water grass" is what sticks to the deck."
/ Rhino coating mower deck #15
Pressure wash after use and paint it in the fall. Still using 5ft bush hog bought new in 1952.
/ Rhino coating mower deck #16
I have the original blades for the Landpride 6 footer plus a set of Gator blades. The Gator blades keep the underside of the deck a lot cleaner.
John Deere 2032R Loader Tractor (A66285)
John Deere 2032R...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
6 Band Wooden Barrel (A61574)
6 Band Wooden...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2002 OilMens 76R 4,200 Gallon Commercial Truck Trailer (A61573)
2002 OilMens 76R...
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
