L4400 front axle leaking. GRRRRR!
/ L4400 front axle leaking. GRRRRR! #1
Greenfield Dave
Greenfield, Indiana
Kubota L4400DT, w/FEL; 2021 Sidekick
After a very frustrating attempt to back a 4 wheel wagon load of firewood, I noticed the front axle leaking inside of the wheel. I had it in 4WD for a short while because the back end was sliding on wet grass, and may have cranked the wheel all the way to one side and goosed it a little too much.
I looked at the parts manual, and there's a plug at the bottom of the front axle case, and that's where it was wet. Anybody have that plug come loose and leak?? That's what I'm hoping is the leak and not a cracked housing or something worse! After the backing fiasco, nothing would surprise me!!
Thanks!
Dave
/ L4400 front axle leaking. GRRRRR! #2
After a very frustrating attempt to back a 4 wheel wagon load of firewood, I noticed the front axle leaking inside of the wheel. I had it in 4WD for a short while because the back end was sliding on wet grass, and may have cranked the wheel all the way to one side and goosed it a little too much. I looked at the parts manual, and there's a plug at the bottom of the front axle case, and that's where it was wet. Anybody have that plug come loose and leak?? That's what I'm hoping is the leak and not a cracked housing or something worse! After the backing fiasco, nothing would surprise me!! Thanks! Dave
I doubt you hurt the axle while backing up. Axle maybe leaking at wheel bearing seal or front hub pivot. My L3830 recently had its front right wheel bearing and seal replaced.
Seal failed causing damage to bearing. There was axle lube on wheel just like your. Grab the front tire and see if there's any slop in it. If there is probably bad wheel bearing and seal. About $160 fix at my dealer.
/ L4400 front axle leaking. GRRRRR! #3
Were those wheel bearings and seals, or bevel case bearings and seals? My L4200 has had a bevel seal leak ever since I got it - I'm up to 90W140 gear oil in the front axle and put a cup under the bevel case when I park. I've filled up a couple of cups, but have yet to need to add any additional oil after two years - still dribbling out of the check hole. My local kubota dealer charges $700-$800 to change those seals. Per side. Which, naturally, is why it still leaks.
JayC
I jacked it up and it does not seem to have any play in it, so I don't suspect a wheel bearing/seal rupture. It only has 450 hrs on it, so I can't imagine a bearing shooting craps, but something did! More investigating tomorrow...
/ L4400 front axle leaking. GRRRRR! #5
I'm wondering if the leak was from some kind of pressure relief from working the 4 wheel vigorously.
Well it seems like it is the oil seal around the front axle. I took the wheel off and degreased the whole area. No visible leaks until I drove around a little, swerving back and forth. Then a seep under the axle, then a bigger seep. So it appears like all I have to do is take the wheel off, remove the bolts that hold the front axle cover on remove the collar and replace the seal. I might go ahead and replace the bearing while I'm in there just for kicks.
Well, I'd say it was the bearing!! It took the seal with it, and scratched the heck out of the axle too! I only worked about 2 hours after I noticed the leak. But I must say, it was pretty easy to replace.
/ L4400 front axle leaking. GRRRRR! #8
If you gave been using UDT, I would suggest a synthetic 75W-90 now although others have suggested 85W-140 mineral oil. 80W-140 would be better yet if you can find it. My first change went directly to gear lube in the front axle.
I changed it at 50 hrs like I was supposed to, and since the book says you can use either, I put hydraulic oil in the axle.. Not doing that again!!
I'm refilling it with synthetic something. for some reason, it's hard to find anything but the WalMart crap, which I refuse to use.
/ L4400 front axle leaking. GRRRRR! #10
Good doing Dave - failures like this are pretty uncommon and usually start with a metallurgical defect in the bearing from new. A defective ball starts to break, damaging the race, eventually jamming and shattering, then another fails because the race is rough, the spreader breaks, and on and on until it runs loose enough to make the seal leak. With the bad parts replaced, you could go right back to doing whatever you were doing and it would almost certainly never fail again. Bearings are made in huge numbers and defects are so rare they probably don't even inspect them. Just bad luck to get a bad one.
/ L4400 front axle leaking. GRRRRR! #11
Thanks for these posts everyone, I have learned some new things today .
Filled it up with 75w-90 Synthetic Lucas oil. $45 a gallon, but still cheaper than new bearings!!
/ L4400 front axle leaking. GRRRRR! #13
<img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/387200-l4400-front-axle-leaking-grrrrr-140819_0001-jpg"/>
Looks like my L3830 failure. I think my seal failed which caused the bearing to fail....
That would be my guess, but we will never know which failed first. I'm just glad the damage was contained between the ring gear and the housing. Otherwise the debris could have made it's way to many more bearings...
/ L4400 front axle leaking. GRRRRR! #15
1,000,000 % truth right there ^^.
And just another reason to NEVER "tap on" or "beat on" a good bearing. Always use a press or puller. When mechanics beat on bearings, or use impact guns on a axle nut through a hub, it has a high potential to pound the inner and/or outer race causing a very, very premature failure.
Unless the seal allowed a contaminet into the bearing, it was probably the other way around. Typically, seals fail (leak) for two reasons. Old age, or a wobble effect due to another part failure.
I highly doubt the bearing/seal failure was related to the lubricant in front axle of the OPs tractor. Heck you could probably use olive oil in the front end and it would last longer than that (with a "good" bearing. :):)
Just for kicks, I just looked up how many revolutions per mile my pick tires turn. I replaced both sealed hub assemblies at 100K miles because one was howling. 685 revs per mile X 100,000 miles = 68,500,000 revolutions. And those are sealed units that operate at a much, much higher speed. I replaced both just because, but one was still good.
How many revolutions on the L4400? No idea, but way under 68 million. Defective bearing? Yes. lol
"New means new, not good". :D
/ L4400 front axle leaking. GRRRRR! #16
:D
The metal retaining spring in the seal failed... Separated and ended up getting into the ball bearings causing them to wear out.
Did you work on my tractor? Didn't think so. (0:
/ L4400 front axle leaking. GRRRRR! #17
Bump to an old thread: My L4400 right front axle case started leaking around the pivot point. I read all the DIY threads about this and decided against doing it myself. But I did remove the case itself and took it to the dealer rather than sending them the whole tractor. They replaced the large top seal at the pivot point, the seal cap at the bottom, the big o-ring on the bevel gear and the o-ring for the case assembly itself where it meets the axle tube. The cost was $245 which I thought was very reasonable. I do not know how much more it would have cost if I'd just take the tractor in but the dealer just said "a good bit more" and seemed glad not to have to deal with the tractor.
To get the unit off you have to remove the 4 case screws and the tied rod end. The shop manual says to pop the tie rod end out with a special too. I did not do that and just unscrewed the tied rod at the grease seal. Quick and easy. You just have to make sure your toe-in is correct when you put it all back together.
Getting the case loose was a bit of a chore. Not sure why but it took a lot of prying, pulling and banging. It is heavy. Not unmanageable but quite awkward. I had a chain hoist at the ready but did not need it. I was able to get it back on by myself (no helper). Also a bit awkward as the axle splines have to line up. Also be aware the the axle will pull right out of the diff. Its no big deal, you just put it back in.
Anyway, that's how I got it resolved. (Of course it has been leaking for over a year and I just now got around to it. During that time I kept the axle full of 85-140 gear oil. Thick as syrup. Fortunately all internals and bearing still looked pristine.
/ L4400 front axle leaking. GRRRRR! #18
N80--great info. Thanks.
/ L4400 front axle leaking. GRRRRR! #19
This used to be a regular event when I had my front wheels set to the widest position. I still have a complete set of pivot seal, inner and outer bearings and seals on the shelf collecting dust now. When the wheels were set wide, all of the load was on the smallest outside bearing. Also cracked housings due to the the out of whack load path. Have had no issues for the past couple thousand hours or so on the L2550DT after going back to narrow. Tractor is now sitting at about 5500 hours.
