kubota b3030 pto select problem
   / kubota b3030 pto select problem #11
can you tell me how to start my own tread? i'm new to site and can not figure out how to? it looks like I was on other people threads asking how to fix my tractor
i'm fseigler would you point me in right place please!
   / kubota b3030 pto select problem #12
You are unable to move the PTO on/off lever forward to the "on" position, is that right?
Are you able to move the front/rear/both lever without problem?
With the engine off, can you turn the rear PTO shaft by hand, even just a little bit in each direction?
No Can not move lever, for the selection of rear or rear/middle
i'll go and try turning the PTO with Tractor off
thanks for your help
the other thing is how do I start a thread of my own????
   / kubota b3030 pto select problem #13
Select the "Forums' tab which is near the top left of any page on this site (just under the TractotByNet logo). Scroll down to find the forum in which you want to start a thread - such as "Kubota Owning/Operating". Click to select your chosen forum, then click on "+ Post New Thread". Enter a title and the body of your question. Click on "Submit new thread" when finished.
NEW HOLLAND TS6.130 TRACTOR (A51406)
NEW HOLLAND...
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52128)
1994 Thomas Built...
Mayrath 10 x 32 Auger (A50514)
Mayrath 10 x 32...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
