stoyan79
Gold Member
- Joined
- Sep 21, 2011
- Messages
- 383
- Tractor
- Kubota L3700SU, TYM 4820CH
The tractor has only 33 hours, bough new in 2011.
I was cutting grass with my 72" cutter and noticed when grass is dense the RPMs would drop, the tractor has lost power and was sputtering. In few minutes, didn't have power to spin the cutter again, so I drove it back to the garage.
I figured it was fuel issue, so I changed the filter and bled the system. Tractor will only start with bleeder screw open, if I close it, it dies.
So I figure plugged hose. Got all fuel out and cleaned hoses with air. Drove to gas station, got new fuel and filled the empty gas tank with new fuel.
Now tractor won't start even with bleeder screw open, although it sounds like its trying to start with bleeder screw open. When screw is closed it doesn't even try.
Figured bad gas cap. Tried to start with gas cap off. Didn't work.
Figured plugged air filter. Tried to start with filter off. Didn't work.
I am out of ideas. Please help.
