Ratchet top link
/ Ratchet top link #1
Professor Marvel
Virginia near Culpeper
Ford 5000, Kubota 2150 HST, NH TC45 D, JD 375 Baby Skid Steer --- STUFF THAT GOES ON EM, Schwinn Stingray
Looking for a cat 1 ratchet top link. Thought I had seen them at the local tractor store but when I went to buy one I couldn't find any. I read about taking a ratchet binder or jack and welding ends on it but I just want to buy one. Can anyone direct me to them?
Thanks
/ Ratchet top link #2
google search "ratchet top link" without quotes
lots of places to buy from come back for me.
below image is from 3-POINT RATCHET JACK
after posting a few days ago, i have not ran across the chain binder style yet.
below image is from Towing Load Binders + Binder Chains | Trailers + Towing | Northern Tool + Equipment
/ Ratchet top link
That jack might work if the threads on my top link match the threads on the jack but with my luck I am pretty sure they wont
/ Ratchet top link
that is what I need
I will try to contact them about a cat 1
/ Ratchet top link #6
Let us know if you find one, I could use one on the Toolcat.
/ Ratchet top link #7
Unless the ends of that Cat II one are too big for the tractor or implements, couldn't you just use a bushing on each end to sleeve it down to fit Cat 1 pins? The length of it looks like it wouldn't be a problem, but I dunno.
/ Ratchet top link #8
Just buy a ratchet jack and weld category 1 ends onto it. I don't know where you can buy ends in the States but in Canada they are available from Princess Auto
/ Ratchet top link #9
alright i feel like a bigger fool than normal. when i posted pictures, i wasn't paying attention and grabbed U ends ratchet jack. but now that i go back and google the stuff up. i am barely getting any ratchet jacks, let alone the cat 1 or cat 2 ratchet jack top links with swivel ball ends. i had amazon, ebay, (grainger or harbor freight don't remember which), and at min 4 other places that were showing pictures of a complete assembly. to make it a cat 1 top link setup.
google search "replacement 3pt top link screw" to change out the U ends for cat 1 swivel ball ends.
Top Link End Cat 1 Thread L.H. Swivel End
Top Link End Cat 1 Thread R.H. Swivel End
Tractor Top Links, 3 Point Hitch Top Links, Cat 1 & 2 Hydraulic Top Links, Top Link Ends, 3 Point Hitch Parts
cut and welded notation
http://www.tractorbynet.com/forums/build-yourself/180100-almost-quick-hitch-ratchet-top.html
doesn't do ya much good from Australia
TOP LINK ASSEMBLY WITH RATCHET JACK ATTACHMENT | Top Agrispares
/ Ratchet top link
/ Ratchet top link #11
This would be the simplest , if you don't find a cat 1.
/ Ratchet top link #12
Unless the ends of that Cat II one are too big for the tractor or implements, couldn't you just use a bushing on each end to sleeve it down to fit Cat 1 pins? The length of it looks like it wouldn't be a problem, but I dunno.[/QUOTE]
The retracted length might be a problem on some attachments. Plus both ends have to be narrowed and any store bought bushings would have to be cut shorter also.
The cat 1 top link on our Toolcat adjusts from 20 to 29 inches. I think most tractor top links are shorter than that.
/ Ratchet top link #13
View attachment 386019 View attachment 386018
I just noticed that the Cat 2 ratcheting toplink posted above has a min/max length of 25.75 - 32.75 inches. I think a typical Cat 1 toplink is 21 - 28 inches. So the Cat 2 one might be too long for some uses.
/ Ratchet top link #14
what is the harm of unscrewing the ends, and simply cutting the ends down, both the "ball ends" and the center pipe ratchet itself?
/ Ratchet top link #15
Where are you going to cut the center pipe ratchet?
/ Ratchet top link #16
/ Ratchet top link #17
Ratchet Jacks
getting closer this one based in canada, and better yet, the handle bends over 90 degrees to keep it from getting in the way of the PTO shaft.
/ Ratchet top link #18
This seems like it would be an easier solution, and would make top link adjustments quicker too:
HYDRAULINK CATEGORY 1 TOPLINK
A bit pricey at $185, but less than a "full on" top and tilt (which I recently finished installing on my tractor).
bumper
/ Ratchet top link #19
/ Ratchet top link #20
Ratchet Jacks
‘Yep, closer, length is right but the ball end has a 1 inch hole, so it would need a bushing to 3/4 inch.
2022 EZ-GO ELITE...
Ford F800 (A63689)
Ford F800 (A63689)
WACKER NEUSON LIGHT PLANT (A65643)
WACKER NEUSON...
More info coming soon (A61569)
More info coming...
(4) Ratchet Straps (A65583)
(4) Ratchet Straps...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
