Ratchet top link
/ Ratchet top link #1
Professor Marvel
Virginia near Culpeper
Ford 5000, Kubota 2150 HST, NH TC45 D, JD 375 Baby Skid Steer --- STUFF THAT GOES ON EM, Schwinn Stingray
Looking for a cat 1 ratchet top link. Thought I had seen them at the local tractor store but when I went to buy one I couldn't find any. I read about taking a ratchet binder or jack and welding ends on it but I just want to buy one. Can anyone direct me to them?
Thanks
/ Ratchet top link #2
google search "ratchet top link" without quotes
lots of places to buy from come back for me.
below image is from 3-POINT RATCHET JACK
after posting a few days ago, i have not ran across the chain binder style yet.
below image is from Towing Load Binders + Binder Chains | Trailers + Towing | Northern Tool + Equipment
/ Ratchet top link
That jack might work if the threads on my top link match the threads on the jack but with my luck I am pretty sure they wont
/ Ratchet top link
that is what I need
I will try to contact them about a cat 1
/ Ratchet top link #6
Let us know if you find one, I could use one on the Toolcat.
/ Ratchet top link #7
Unless the ends of that Cat II one are too big for the tractor or implements, couldn't you just use a bushing on each end to sleeve it down to fit Cat 1 pins? The length of it looks like it wouldn't be a problem, but I dunno.
/ Ratchet top link #8
Just buy a ratchet jack and weld category 1 ends onto it. I don't know where you can buy ends in the States but in Canada they are available from Princess Auto
/ Ratchet top link #9
alright i feel like a bigger fool than normal. when i posted pictures, i wasn't paying attention and grabbed U ends ratchet jack. but now that i go back and google the stuff up. i am barely getting any ratchet jacks, let alone the cat 1 or cat 2 ratchet jack top links with swivel ball ends. i had amazon, ebay, (grainger or harbor freight don't remember which), and at min 4 other places that were showing pictures of a complete assembly. to make it a cat 1 top link setup.
google search "replacement 3pt top link screw" to change out the U ends for cat 1 swivel ball ends.
Top Link End Cat 1 Thread L.H. Swivel End
Top Link End Cat 1 Thread R.H. Swivel End
Tractor Top Links, 3 Point Hitch Top Links, Cat 1 & 2 Hydraulic Top Links, Top Link Ends, 3 Point Hitch Parts
cut and welded notation
http://www.tractorbynet.com/forums/build-yourself/180100-almost-quick-hitch-ratchet-top.html
doesn't do ya much good from Australia
TOP LINK ASSEMBLY WITH RATCHET JACK ATTACHMENT | Top Agrispares
/ Ratchet top link
/ Ratchet top link #11
This would be the simplest , if you don't find a cat 1.
/ Ratchet top link #12
Unless the ends of that Cat II one are too big for the tractor or implements, couldn't you just use a bushing on each end to sleeve it down to fit Cat 1 pins? The length of it looks like it wouldn't be a problem, but I dunno.[/QUOTE]
The retracted length might be a problem on some attachments. Plus both ends have to be narrowed and any store bought bushings would have to be cut shorter also.
The cat 1 top link on our Toolcat adjusts from 20 to 29 inches. I think most tractor top links are shorter than that.
/ Ratchet top link #13
View attachment 386019 View attachment 386018
I just noticed that the Cat 2 ratcheting toplink posted above has a min/max length of 25.75 - 32.75 inches. I think a typical Cat 1 toplink is 21 - 28 inches. So the Cat 2 one might be too long for some uses.
/ Ratchet top link #14
what is the harm of unscrewing the ends, and simply cutting the ends down, both the "ball ends" and the center pipe ratchet itself?
/ Ratchet top link #15
Where are you going to cut the center pipe ratchet?
/ Ratchet top link #16
/ Ratchet top link #17
Ratchet Jacks
getting closer this one based in canada, and better yet, the handle bends over 90 degrees to keep it from getting in the way of the PTO shaft.
/ Ratchet top link #18
This seems like it would be an easier solution, and would make top link adjustments quicker too:
HYDRAULINK CATEGORY 1 TOPLINK
A bit pricey at $185, but less than a "full on" top and tilt (which I recently finished installing on my tractor).
bumper
/ Ratchet top link #19
/ Ratchet top link #20
Ratchet Jacks
‘Yep, closer, length is right but the ball end has a 1 inch hole, so it would need a bushing to 3/4 inch.
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
2015 Chevrolet Silverado 3500 Pickup Truck, VIN # 1GB4KZC88FF627993 (A65563)
2015 Chevrolet...
E-Z Trail 3400 Gravity Wagon (A66285)
E-Z Trail 3400...
Front Tank Bracket (A64126)
Front Tank Bracket...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
