Kubota 2500 loader control sticking
/ Kubota 2500 loader control sticking #1
criswelg
Anahuac, Texas
Kubota 2500 DT,MF 135,Cub Cadet
The loader control on my Kubota 2500 Has started sticking. I lubed everything I can get to. It was sticking in the up mode after exercising it quite a bit it is sticking in the down of float position?
I used to could raise the front wheels when I put the bucket down (even though it says FLOAT) but now it just lowers not powers down?
Tractor has only about 550 hrs on it.
Any ideas?
Thanks:anyone:
/ Kubota 2500 loader control sticking #2
Float has no power as the cyl fluid is open to tank.
Remove and clean the spool.
Not sure id I fixed it but I got it working again.
Revved up the engine and raised and lowered several times fast as I could then raised it all the way up and just kept bumping it into float and finally I felt something change and it started working correctly again.
Stout Buckets HD78-3 Rock Bucket Skid Steer Grapple (A65640)
Stout Buckets...
New/Unused ATS 40 Gallon 2 Stage Air Compressor (A65583)
New/Unused ATS 40...
3pt 14' 15 Shank Chisel Plow (A64127)
3pt 14' 15 Shank...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
2011 Bobcat E80 (A64126)
2011 Bobcat E80...
