Kubota 2500 loader control sticking
   / Kubota 2500 loader control sticking #1
criswelg
Anahuac, Texas
Kubota 2500 DT,MF 135,Cub Cadet
The loader control on my Kubota 2500 Has started sticking. I lubed everything I can get to. It was sticking in the up mode after exercising it quite a bit it is sticking in the down of float position?
I used to could raise the front wheels when I put the bucket down (even though it says FLOAT) but now it just lowers not powers down?
Tractor has only about 550 hrs on it.
Any ideas?
Thanks:anyone:
   / Kubota 2500 loader control sticking #2
Float has no power as the cyl fluid is open to tank.
Remove and clean the spool.
Not sure id I fixed it but I got it working again.
Revved up the engine and raised and lowered several times fast as I could then raised it all the way up and just kept bumping it into float and finally I felt something change and it started working correctly again.
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
4 Pallets of Vehicle Seats (A53425)
4 Pallets of...
2010 FREIGHTLINER CASCADIA TANDEM AXLE MID ROOF SLEEPER (A56138)
2010 FREIGHTLINER...
Misc IT Accessories (A53425)
Misc IT...
2019 ROCK LINE RS8-32 80" X 9' HYD DROP DOWN TRAIL (A52706)
2019 ROCK LINE...
1065 (A53342)
1065 (A53342)
