Racor installed on DS3510
/ Racor installed on DS3510 #1
Buckgnarly
West topsham VT
Kioti DS3510
After being inspired by the installs on here, finally got around to doing mine. Mounted on FEL mount, before the lift pump. Left the old one after the pump for double protection. Mainly wanted the Racor for the water separation (had a **** of a time with water and the old plow truck last year, do not want that again!) and the easily seen and drained bowl. Got the filter and housing for 50 bucks IIRC from Ebay, best 50 bucks spent for Kitoti so far!
/ Racor installed on DS3510 #2
Great mod.I like it.
/ Racor installed on DS3510 #3
Looks good.
Click bond mounts?
You'll appreciate the better filter for sure. I just changed mine after 105h. Im running the 2 micron (s) vs. the 10 micron (T) however. I was willing to trade maximum filtration for a longer life. The filter elements are cheap anyways.
Looks good.
Click bond mounts?
No, kind of looks like it though! Just two fender washers with rubber backing to seal the two tapped holes. I thought if click binds when I saw that perfect spot, but just do not have the patience to order them and wait! Might just have to keep some on hand now, or plan better!
I was thinking of going with an even finer filter when it's time to replace, good to hear it works.
2011 WESTERNSTAR 4900SA (A63569)
2011 WESTERNSTAR...
2015 CAT 259D Track Loader (A63111)
2015 CAT 259D...
2017 Unverferth 1245R-35 Rolling Harrow (A63116)
2017 Unverferth...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
