Adding 62D mower to a 2320 advice needed please.
   / Adding 62D mower to a 2320 advice needed please. #1
bigpinwheel
Ohio
Deere x500, Deere 2320
I just put a deposit on a nice low hour private party unit that has never had a mid mount mower installed. :thumbsup:
I was wondering if anyone has undertaken the process of installing the mower without taking the tractor to a dealer. I see that Mutton Equip sells the mower and what I would assume is the complete mounting hardware specifically for the 2320. The lift arms are on the tractor already I assume and would only need the attaching hardware. I understand that I need the 62D1 deck specifically.
John Deere 62" Drive Over Mower Deck
One of my concerns is all the discussion surrounding the mechanical deck lift and the independent lift. I think I would be happy with the mechanical lift as I don't foresee locking the deck up for use with the 3 point hitch to be a problem.
My other concern is the problems that seem to be apparent with the deck height adjustment mechanism. Is this enough of an ongoing issue that you would recommend having a dealer install the mid mount mower so I have support in that arena.
Thanks so much, I'm excited about my new rig, pickup this weekend, but I need the mid-mount as the cherry on top. :cool2:
   / Adding 62D mower to a 2320 advice needed please. #2
I assume you have the mid-PTO on your 2320. Hope this all works out well for you.
I do indeed.
   / Adding 62D mower to a 2320 advice needed please. #4
If you are confident in your skills at turning a wrench I think you would easily be able to handle this task on your own. The owners manual that you get with your mower should take you step by step all the way through assembly, installation and removal. I know the manuals for my JD loader and backhoe for my 4310 even went as far to properly uncrate the implements.
As for attaching hardware. I would guess that your JD dealer would have to order that separately. Shouldn't be too hard thing to figure out though. Send some picks of the undercarriage and show them what you go and they can go from there.
As for independant or mechanical lift. I would just start with the mechanical and go from there. You can always add the independent later if you like. Plus I believe the independent has its own separate hydraulics so it's probably a pricey add on that you might not even need.
As for the deck adjustment mechanism I haven't heard too much about it on the JD forum but I don't doubt you. You best bet on that is to ask Mutton's if they have seen any issues with it or if there is a TSB out for the deck height adjustment. They move a lot of JD tractors so I'm guessing if it is a common problem they have seen it. The biggest issue I have seen people complain about with the MMM is that the linkage hangs low when the mower is off and no factory way to keep it propped up.
Thanks for the response I can turn a wrench okay if it's just a matter of hooking up bolt on brackets etc.. I'm just unsure of the details and if there are any additional concerns. I've looked at the manual and makes it sound like there are no additional considerations as if all I need is the proper deck. I will call my dealer if I don't hear from someone who has done this first hand.
I was digging through jdparts and these parts and the deck seem to be all I would need, I think I have these parts already on the tractor but will have to wait until I get the tractor home to be sure.
   / Adding 62D mower to a 2320 advice needed please. #7
Why not just keep the x500 for mowing? I recently bought a used 455 because I was tired of switching between the MMM and FEL all the time.
I'll be keeping the x500 for part of my mowing and 2320 will be used fairly routinely for driveway maintenance (gravel and snow). I have some rougher parts of my yard/field that beat the x500 and my back while testing the longevity of the X500. I think I could benefit from the longer wheelbase and larger tires. I wont be using the loader etc enough to justify owning the CUT without having it taking on some of the mowing capacities. I currently keep 5 acres mowed per her request but I will be testing the wife approval factor with a brush hog cut of the grass before I go all in on the 62D.:rolleyes:
   / Adding 62D mower to a 2320 advice needed please. #9
There's a member on GTT that has a LVB25620 2320 Mower attaching parts kit for sale. It's new and unused and you'll need it if you pick up a 62D1 for your new 2320. He also has the LVB25630 Independent Lift Kit which would nice a nice option as well.
   / Adding 62D mower to a 2320 advice needed please. #10
You'll also need this for attaching the front of the mower deck to the 2320. Front draft arms.
NEW HOLLAND TC55DA TRACTOR (A58375)
NEW HOLLAND TC55DA...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2004 Dodge Dakota Pick Up (A55272)
2004 Dodge Dakota...
2014 Case 601D Directional Drill (A57453)
2014 Case 601D...
Year: 2019 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 24,981 Plate: Body Type: 4 (A59230)
Year: 2019 Make...
2000 Mack CH613 MaxiCruise (A57148)
2000 Mack CH613...
