Adding 62D mower to a 2320 advice needed please.
   / Adding 62D mower to a 2320 advice needed please. #21
I believe that the drive-over deck bracket plates are different due to the track width variation between 2520, 2720, 2032R VS. 2320, 2025R machines. The driveshaft may be too long as well. You may be able to purchase the appropriate section to make it fit. Of course you're aware that the deck mounting hardware is entirely different as well.
   / Adding 62D mower to a 2320 advice needed please. #22
Got the kit installed on the tractor.
I guess the front quick hitch "box" can't be on at the same time as the mower brackets, which is pita!
I skip the independent hydraulic lift for now.
The drive shaft on the 62d2 is too short. So I'll need to buy a new one I suppose. :(
1991 MACK CH613 DUMP TRUCK (A58214)
1991 MACK CH613...
2012 DOOSAN G25KW GENERATOR (A58216)
2012 DOOSAN G25KW...
Electric Utility Cart (A56857)
Electric Utility...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56438)
2008 Ford F-250...
DEUTZ MARATHON 60KW GENERATOR (A58216)
DEUTZ MARATHON...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
