Is a cab top heavy?
   / Is a cab top heavy? #1
Citydude
Super Member
Northeast Wyoming
Kubota L4060 HSTC
I'm throwing around the idea of getting a cabbed tractor for my mowing business due to allergies that I recently acquired. I currently have a L3400 with loaded rear tires and 4" spacers on each rear axle. This thing is very stable on slopes. Would it make a difference in stability if, for instance, it was cabbed?
   / Is a cab top heavy? #2
Well, you'd be adding weight up high, which has to affect the center of gravity at least a little just by the laws of physics. Whether it will affect it much, I don't know.
You could probably offset some/all of that by adding wheel weights and/or filling your tires if they're not already filled. Also, setting your tires to the widest setting would be important.
   / Is a cab top heavy? #3
You will never regret getting a cab on your next tractor. The extra weight is not significant.
I didn't have to breath this and the A/C is nice also.
I will never ever, ever, ever, buy a tractor without FEL or Cab.
Sent from my iPad using TractorByNet
   / Is a cab top heavy? #4
Last weekend. Which did I enjoying using most? You get three guesses and first two don't count.
After 4 hours Monday with blower and pressure washer.
No rain this week, so far, so will probably start all over again this weekend.
   / Is a cab top heavy? #5
I'll have to ponder some on the effects a cab has on the center of gravity as I sit in the comfort of my A/C cab while it's 102 degrees outside listening to music able to hear myself think sipping a bottle of water with no need to dust off after a day of work.
   / Is a cab top heavy? #6
In all seriousness. You see more highway mowers in cabed tractors cutting the steep on ramp sides than you do open station. My property has some fairly rocky slopes and I've not felt any difference than when I had an open station.
   / Is a cab top heavy? #7
Well stated C4. My pastures have lots of oak trees that the NH TL100A cannot get under. So have to use the open station Kubota for that, and the JD Zero Turn for the really low trees. The JD is, by far, the dirtiest when it is dry.
My bride can't understand why I won't wear a dust mask when on the Kubota or JD, when it's dry? How much good is a dust mask with a 50 ring hole for cigar???? :- D
I do wear hearing protection because don't have to stick cigar in my ear. ;-D
Yes, cabs are worth every extra cent they cost and then some. A big plus is that they hold their value if ........... you don't beat the crap out of them.
   / Is a cab top heavy? #8
without repeating what others have said...
cabs...
generally get a larger alternator vs open station / no cab, meaning better 12v stuff can be plugged in for longer times with less fear of running battery dead.
get upper front and rear work lights generally
a/c is optional, at bare min heat in the winter (big thing for me)
possibly review mirrors. if mirrors are exterior they will get ripped off if ya in and around trees, make sure you can put something back on after they break off.
when the windows get dirty or sun is just right, there can be some extra glare, making it hard to see FEL (front end loader) bucket and position it is in,
front window easy to clean, it is the side and rear windows that can be a pain to clean on the outside.
if no A/C, and you have windows / doors open when driving, wind can nail you good with exhaust fumes all of a sudden.
if working in the mud in your boots, cabs can be a pain to clean all the mud and like that can get tracked into it.
working in the woods or in tight spaces, cabs can be a pain to get in and out of.
if no A/C, cabs can get hotter than no cab in the summer, (assumption some sort of shade is provided either attached to tractor or a large straw hat is worn.
Thanks for all the responses. It sounds as if the added weight wouldn't be an issue. That's a concern I wanted to eliminate while exploring the cab, no cab decision.
   / Is a cab top heavy? #10
If you operate in conditions like Rick(rigustafson) does - you will surely need something to stop all that dust. I would think that in those conditions an open station and the world's best dust mask would soon become intolerable. I have an open station tractor so this time of year when I do any dirt work on the property I'm very aware of the direction the wind is blowing. I don't mind the dust as long as I can stay up wind - and that is my limitations. Also, if I were going to use a rear cutter, which I don't, I would have most definitely purchased a cab unit when I bought this new tractor.
LOT: (2) Truck Brake Part #'s 66864B, (2) Truck Brake Part #'s RK8354709E2 (A59076)
LOT: (2) Truck...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
David White LT6-900 Level Transit, S/N C500926, Model 8834 (A59076)
David White...
