ferris F800X ?
/ ferris F800X ? #1
vaskeet
camden Nc
Kubota l2250
does anyone use one of these? how does it compare to ztrs ? Is the 31 vanguard enough engine for it and is it a good motor Thanks
/ ferris F800X ? #2
As much as I love my Ferris 700Z, I would be looking at a diesel Kubota F series if I were going to spend $16K or more for a mower.
/ ferris F800X ?
So would I but on the F800X with 31 vanguard and the 60 in deck I have I have a price quote of $10,900. which is a long way from 16k
/ ferris F800X ? #4
It's a nice mower. Yes it has enough power.
/ ferris F800X ? #5
The reason I put in $16K is that is what the Ferris website I found was selling them for with a 72" deck IIRC. $11K is better but I would think that anyone buying a huge industrial mower would want a diesel engine. Several makes of those front deck mowers, like Kubota and Toro in 4 wheel drive models.
Personally on my hills, 52" is a bit wide to prevent scalping.
EDIT: I went back and looked at that site on ebay and it was a 72" deck with a 30 HP Yanmar Diesel engine, so not so bad of a price after all with the diesel engine and 72" deck.
/ ferris F800X ?
I am trying to decide what I want in the running are the ferris I3100 and the F800X the scag cheetah the badboy outlaw xp and the big dog diablo mp and the Kubota zd 326 and the bad dog compact diesel all with 60 inch decks. There are things I like about each of these mowers and things I don't like. Priced run from mid $8k (big dog and bad boy outlaw) to $13 k (Kubota zd326) I cut about 8 acres some of which are pasture. I have no slopes or hills but do have some wet areas I am looking at the 35/37 hp motors (Kawasaki or briggs Vanguard) on most of the above mowers
/ ferris F800X ? #7
Only experience with a Ferris IS700Z. We do some small pasture mowing with it and mow our paddocks close to the barn with it. For pasture mowing the suspension is a big plus. Horses make for very bumpy ground. The Ferris is tough enough.
/ ferris F800X ? #8
The FX800 is nice, just remember it's almost 3' longer (34") than the IS3100. I have the IS3100 with the Kawasaki 37 hp and added a suspension seat because I mow lots of rough ground. It turned a teeth jarring event on the lawn tractor to almost fun. I spend less than half the time and I mow more. I wanted one good mower before I die........:)
/ ferris F800X ? #9
31hp is plenty for 60" deck. My mom's 345 has 20hp with a 54" deck. I have a bunton 3 wheeler 71" deck and 25hp. It is fine for general mowing unless you get into real tall/thick stuff. My bunton supposedly goes about 8 mph and I could run full speed most of the time unless i wait too long to mow, problem is I can't go full speed on a lot of my yard because it's too bumpy. I guess suspension could change that. How fast do you want to mow and how fast will that Ferris go?
/ ferris F800X ? #10
Really not so much faster with a Ferris suspension. But you can mow hours longer with it because the ride doesn't beat us to death. Suspension doesn't mean quicker. Suspension means longer mowing time with less fatigue.
/ ferris F800X ?
the extra length is not a problem. I like the fact that the deck raises up so you can get to the blades easier
/ ferris F800X ? #12
If you're looking at front-mounted mowers, be sure to look at Grasshopper too. They make both gas and Kubota diesel powered front mounts. They are a very high quality mower. A lot of commercial guys run them.
I would LOVE to have a front-mount. It sure would make changing blades and cleaning the mower deck easier. But they are really expensive.
/ ferris F800X ?
the closest grasshopper dealer is 100 mile away so for me that means they are not a option
/ ferris F800X ? #14
If the deck raising to get to the blades easier is a game changer for you that narrows down the field quite a bit.
/ ferris F800X ?
not a game changer as of now the 3 leading choices are the scag cheetah, ferris is3100 and the Kubota zd326 (I own a Kubota tractor and Kubota offers 0% for 60 )
/ ferris F800X ? #16
You do have some high quality mowers on your list. Maybe test drive a few. That's how we decided. I don't think you can go wrong with those that you have chosen. Your final choice would be of interest.
/ ferris F800X ? #17
I really like my Scag mower.
/ ferris F800X ? #18
It would be really hard to go wrong with any of those three. If you get a mid-mount like one of those (instead of a front-mount with the fold up deck), you can get a MoJack Pro to lift it for deck cleaning and blade changing. They are about $450 at Amazon, but I hear good things about them.
/ ferris F800X ? #19
Or a floor jack. That's what I use.
/ ferris F800X ?
I would not need a jack with the Kubota zd326 because it has the pivoting front axle to raise the mower It may be as far away as in the spring of 2015 before I get the new mower (want to pay off tractor first) I am also looking at the big dog diablo MP series (hustler super z with red paint) it would be the cheapest with the longest warranty but I am not sure about the kawasaki fx1000 engine I know they had some problems awhile back
24 Gauge R Panels (A65640)
24 Gauge R Panels...
JOHN DEERE 1210A GRAIN CART (A64277)
JOHN DEERE 1210A...
2005 Butler pole trailer (A62679)
2005 Butler pole...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
Land Pride RB3584 3Pt Blade (A66408)
Land Pride RB3584...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
