I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be.
   / I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be. #21
Hiya,
Yet another oil thread that ends up with people getting cranky. :mur:
What is really the factor for longevity is changing whatever oil you use more often than the manual says to. Keep in mind that these small air cooled engines operate in a very hostile environment, the best thing you can do is change the oil to get rid of the microscopic dirt that is suspended in the oil. Don't fool yourself, the tiny oil filters on these don't catch and hold the small, less than 20 micron sized abrasives that cause wear and damage. To have really clean oil, you need supplemental by-pass filtration, down to less than 1 micron, something impractical on these sized machines. If your engine doesn't have a filter, change the oil more often.
Use the weight or grade your manual states for the temps you are expecting to see during the time you plan to have that oil in the engine. Change it more often than the severe service timeline says to and don't forget to clean around the fill cap before you put oil in. Do that, keep the cooling fins clean and clear of chafe and debris, only run your equipment at maximum throttle when you really need to and it will last for years.
Here's an example, 30+ years ago I worked for a school department. During the summer, 4 of us had to cut lawns at 31 schools. 5 days a week for 12 weeks we cut acres of grass with 21" Bobcat push mowers. We got 4 brand new mowers with 4 HP B&S engines. At the end of mowing every day, I would walk my mower over to the fuel oil tank fill, dump the oil out then fill it with fresh 30wt (The schools used #4 bunker so 12Oz of engine oil wouldn't make a difference in 4000 gallons) At the end of the summer my mower was the only one that ran well, 2 had rod failures, the 3rd ran but smoked and mine ran well.
My 2 cents,
Tom
Well peeps, I am going to use a good synthetic oil,(Mobil1) I am going to use the John Deere oil filter, I am going to change my oil every 20 hours, I will put about 125ish hours on the mower in 4 years, then, the warranty will be over, then, I will trade for another new one.Ha,Ha,Ha,Ha.
And, I will sleep like a baby every night.LOLOL
   / I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be. #23
Synthentic is the superior lubricant and for many reasons. Brand choice is usually affected by availability, quality and cost. You have made all good choices.
Thank you, Carguy : ) on my X360 that I traded in with 122 hours on it, I used John
Deere oil and filter the whole time, it did ok.))))
   / I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be. #25
Amsoil make a 4stroke small engine oil that is 10w-30/30 wt combo.. I am running it in the push lawn mower and generators now..
It appears that most amsoil dealer will sell to anyone at the 'wholesale' (their cost) - BUT they do get rebates/kicksbacks/incentives for sales volume - so they do make money on the deal
Brian
   / I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be. #26
Hiya,
Here's an example, 30+ years ago I worked for a school department..... At the end of the summer my mower was the only one that ran well, 2 had rod failures, the 3rd ran but smoked and mine ran well.
My 2 cents,
Tom
30 years ago says it all ... SC or SD oil back then ... you did alright changing the oil more frequently ( as you knew you should )
changing the oil more frequently NEVER hurts an engine .... but waiting too long and .......
   / I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be. #27
Thanks, and yes, you did. Improved lubrication will greatly help extend a motor's sevice time before any component wear or failure sets in. It also provides assurance that there is one less external influence and variable in the total performance of the machine. Here you were able to trade up, and with pleasure, to another John Deere.
   / I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be. #28
Noobie on syth oil here:
I noticed in the video, all the different brands of synth said "for gasoline engines".
Most regular oil on the shelves is for gas engines, but some is marked "Heavy Duty Diesel". I don't see any synth marked 'for diesel use".
My PU uses full synth, my wife's new car uses full synth, I'm going to put full synth in my Cub lawn tractor and I'd like to use it in my new Mahindra.
I'd like to get rid of the old oils and stick to all synth...less confusion that way.
What synth is recommended for diesels? My manual doesn't mention it.
   / I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be. #29
Rotella T6 is one for diesels ...
   / I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be. #30
There are other All Fleet diesel oils out there, but T6 is a decent one, and widely available. It is rated for many modern diesels requirements (N. America), gas too, and the 5W40 here is even JASO MA rated for motorcycle use.
Verify your oil cert needs in your owners manuals, and if T6 covers all, then you have the convenience of having only one oil to stock.
Rgds, D.
(edit - meaning oldpilgrim's post, not OP Mark - you'll be fine with your M1 choice).
2020 Mathieu MC210 Azura Flex Street Sweeper (A55851)
2020 Mathieu MC210...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
2022 Polaris Ranger 4x4 Utility Cart (A54811)
2022 Polaris...
2012 MACK CXU613 DAYCAB (A55745)
2012 MACK CXU613...
2008 CATERPILLAR 272C SKID STEER (A52705)
2008 CATERPILLAR...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
