I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be.
   / I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be.
But, I was reading another synthetic oil thread on this website, and the consensus was dino oil is just as good as protecting your motor, synthetics give you better start up protection in cold weather and longer change intervals.
So, I could get wishy washy here and just stay with good old dino oil))))))))))))))))))))))
   / I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be. #12
An oil lab's test data covers all of the above with the test results. So to me, the only advantage to synthetic is longer oil changes and it costs a lot more to get to that point. This said, I use synthetics and change gasoline engine oil every 5k miles or so (not cost effective) and every 50 hours on my tractor using regular petroleum.
For what it's worth, my 1996 Jeep Grand Cherokee, AWD, 170k miles, 5.2L engine, auto. trans., heavy winch bumper/winch, carrying a moderate-heavy load every time I drive it, still gets the same 16 MPG it did when I purchased it with 16k miles on the odometer.
   / I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be. #13
I change my tractor oil every fall after the mowing season, I average between 100 to 150 hrs per year. I use Amsoil 10W30 small engine oil in my tractors & Amsoil 10W30 in all my vehicles.
Ha,Ha,Ha,Ha, I think Mobil1 will be OK for meLOLOLOLOL
   / I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be. #17
Yeah. I think oil is oil until one needs something at the extreme ends of things.
   / I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be. #18
Why synthetics are MUCH better than traditional oil.
http://youtu.be/ZivhWIM0Q8s
This will STUN you it did me. I thought Mobil 1 was great...not so much
http://www.qmi.no/teknisk/Norway%20photos/StreetCommodorecover.pdf
This comes right out of the no $h! T sherlock files. You cant test a 0w-40 full synthetic and be suprised when a semi synthetic 10w-40 - or 15W40 out performs it in a wear test your testing bassed on viscosity. Allmost all the low ranked synthetic oils were lower weight.
They should have done a fair comparison on same weight oils. This would have narrowed the variation down and provided a better result. Their is a lot more to oil then just a simple wear test.
If they had tested cheap 0w-40 semi synthetics versus 10w-40 mobil one results would have been flip floped.
The main reason for the OEMs going to lower weight oils was not for durability but because of the E.P.A in there never ending quest to make stuff more expensive and make the tree huggers happy by forcing increased fuel economy.
   / I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be. #19
10w-30 will lubricate your machine just fine. 5w-40 likely provides a broader range, but I've run both in my Kubota and haven't seen any detectable difference in start up, etc, even in subzero weather. I'm a fan of changing oil annually to get the dirt/acids out, not because I necessarily believe the oil itself is worn out, be it dino, semi, or full syn. I also like a quality filter.
Then, I use the machine, check the dipstick for any unexpected use and when night comes, I sleep like a baby.
   / I want to go synthetic on my first oil change,I got one hour left, Mobil1 it will be. #20
go ahead and switch , be happy with your choice:thumbsup: ... 0W40 , 5W30, 15w40, etc any of them will work very well
think of it this way ,,,, the lower the first number makes it easier for cold starts , the higher the second number allows for higher summer temps ....
( yes , higher second numbers loosen up the clearances a bit , but negligible on a new engine )
2010 KMC 3376 Peanut Combine (A55302)
2010 KMC 3376...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
Cat TH407C Telehandler (A53472)
Cat TH407C...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
