Show What Tool You Made*
/ Show What Tool You Made* #241
I thought they might take a dim view of anyone carting off their rail. They are a very possessive outfit.:laughing:
/ Show What Tool You Made* #242
BTW, after at least 2.5-3 years of that rail sitting there seemingly ignored,, I noticed a CSX truck parked across the street from it, with a gu y seemingly sleeping there in it....
That's the guy you needed to ask. An employee of the rail road that might rather let you have it than have to mess with it himself.
/ Show What Tool You Made* #244
This reminds me of the time a few years ago when I wanted about 60 used RR ties. I went to the maintence yard near by where they had a giant pile of them and asked the forman. He told me a long story about how it is against the law for anyone to have RR property or to even be on RR property and that he was not autherized to sell them but if I were to leave a case of beer on the porch of the little building he used as an office/house he didn't really see any problem with me taking what I wanted as long as I did it when the yard was quiet.
/ Show What Tool You Made* #245
"but if I were to leave a case of beer on the porch of the little building he used as an office"
LOL
I visit pour local city re cycle depot every so often and browse thru the paint collection shed.
Couple of well placed $$ lets me chose. My usual grabs are red black yellow tremclad paint and primers.
I have found qts that barely had more than a brush dipping or two. Best find was gal of primer and gal of tremclad gloss black.
Simply amazing what some folks heave out.
Oil based paints withstand freezing but not water based ones.
When it comes to tires he even helps me search for the size I want!
/ Show What Tool You Made* #246
I dont understand why they want money to give back re cycle materials. So much paint is ''destroyed' and could me multi mixed and used. yet we have to pollute more and make new paint.lol
LOL
/ Show What Tool You Made* #247
Back to homade stuff. A belt sander conversion on an old bench grinder, complete with rollerskate wheel.
/ Show What Tool You Made* #250
Recycle centers only take stuff that can be re processed and that they can sell. Rubber gets shredded, paint is multi mixed mixed into cheap 'Blah' colors, paper re cycled, and metals sold to smelters. They don't take construction debris either.
The $$ I gave to the attendant is basically a TIP to allow me to browse and help myself. They frown on folks stealing garbage and my TIP is real cheap shopping.
/ Show What Tool You Made* #252
Yep...a $$ tip has let me to a lot of great finds over the years at town recycling centers. That's the secret wit the gatekeeper.
/ Show What Tool You Made* #253
I'm making some shafts on the lathe using HSS cutting tools. Got tired of standing there with a brush or an oil can which provides either too much or too little cutting oil. Decided to get a setup for directing cutting oil onto the work. But I didn't like the prices for a purpose built tank and pump, or the idea of yet another gizmo to be plugged in and maintained. So I rigged this thing up using a Harbor Freight air tank ($19), a Grizzly magnetic oil stand ($35) and some fittings for an adapter. The adapter I made up has a hose barb on both ends. One end is for a feed tube inside the tank and the other end is for an output tube leading to the oil dispenser. I put about a gallon of cutting oil in the air tank, and installed the adapter (with a bolt taped to the feed line to keep it on the bottom of the tank). I pressurized the tank to a few pounds, and there you are - a very precise amount of oil delivered to the working point. The whole setup can be easily moved to the drill press or milling machine as needed. I keep the tank underneath the lathe on a shelf out of the way, but for the photo I set it up with a short piece of tubing just to show how everything fits together. It seems to last a long time on one pressurization, presumably because the volume of oil dispensed is small compared to the volume of pressurized air in the tank.
/ Show What Tool You Made* #254
I like it!! And portable too.
Terry
/ Show What Tool You Made* #255
I'm too cheap for even the air pig .... small weed sprayer tank ... hand pump style ..... and a limiting valve on the end to regulate the flow .... move it from drill press to lathe to band saw ....
/ Show What Tool You Made* #257
A friend of mine works in the woods running forestry equipment. He needed a tool to turn the pin in the locks of the chains on the machine, so here's what I come up With
verktoslashy3_zps90d5a4a5.jpg Verktoslashy1_zpsa98b12b5.jpg verktoslashy2_zps2fb50910.jpg
/ Show What Tool You Made* #258
/ Show What Tool You Made* #259
A nice gadget you thought up there. Looks to be a lot easier than the way I do it. I am going to steal that one. Thanks for posting.
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
Landhonor ATS-RT15R Mini Excavator (A66285)
Landhonor...
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
2015 Global Environmental Street Sweeper (A64553)
2015 Global...
2000 Pro Stock Utility Trailer (A66285)
2000 Pro Stock...
Gravity Box (A65640)
