Backhoe BACKHOES LETS SEE THEM
/ BACKHOES LETS SEE THEM #421
Nice! Would love to see that ripper in action!
Will try in the next few days to get some pictures or even a video . I am selling the 32 " . I like the 42" blade a lot better it goes down far enough to get the roots of most any tree. It seems to do very good with hard woods it is the larger pine trees that are really hard to get out with their long tap root.
/ BACKHOES LETS SEE THEM #422
We have a 24" bucket so I wind up digging a lot to be able to push over large trees with the FEL. An nice blade like you built would really speed up things I expect when it comes to tree removal. Thanks for showing us your projects and the results.
/ BACKHOES LETS SEE THEM #423
IMG_1820.jpg Hope this picture comes out just as four foot around and 6 -7 foot pine tree tap root finally broke loose the front end came off the ground. It seems to pull out hard woods a lot easier than the huge pine trees them tap roots are a killer.
/ BACKHOES LETS SEE THEM #424
IMG_1822.jpgIMG_1822.jpg It is nice how it just cuts a line across the root ball with out removing much dirt at all. I have pulled out about 35 stumps so far since I built this bigger blade type ripper at 42 inches.
/ BACKHOES LETS SEE THEM #425
IMG_1835.jpg In my PC the pictures are straight for some reason when they get up loaded they are at the wrong angle....I have the 32 inch for sale $800.00 and will be making another 42" shortly at $1500.00
/ BACKHOES LETS SEE THEM #426
View attachment 380383 In my PC the pictures are straight for some reason when they get up loaded they are at the wrong angle....I have the 32 inch for sale $800.00 and will be making another 42" shortly at $1500.00
Are you using a phone to take the pictures with? Turing it sideways to get the wider shot? If so, that can cause it sometimes.
Dang the bad luck! I was pushing up a brush pile with the backhoe today and I heard a loud pop! Then the backhoe was leaning on its side! Thought I broke an axle! But I broke the inside of the rim!
/ BACKHOES LETS SEE THEM #428
You never like it when these things happen and you wished that they did not. But on the other hand better a broken rim than a broken axle.
/ BACKHOES LETS SEE THEM #429
If you plan on welding the rim back together be sure to take the tire off first. Remember that a weld bead shrinks as it cools when you try to true the rim. Less than an 1/8 inch run out can be done without much trouble.
/ BACKHOES LETS SEE THEM #430
My backhoe looked a lot like that about 15 years ago, actually I think it might be the same type of hoe. Mine is a Sherman hoe on a 1964 ford 621. Well anyways I did break the axle and the tire was on the ground I had to lift the tractor with the outrigger to get it off of the tire, forget getting it in the garage at that point!
/ BACKHOES LETS SEE THEM #431
/ BACKHOES LETS SEE THEM #432
Just arrived this morning!
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=382318"/>
Very nice! What your first big project for it?
/ BACKHOES LETS SEE THEM #434
First on the list is lots of stumps, big & small.
Next, I was thinking of using it to hold an implement in the air for painting.
Next is digging some pools for wildlife.
Then some runoff drainage pipe work.
By then I should have enough skill developed to tackle some foundation drainage work & house addition work.
If I don't do too much damage with it, it should pay for itself in a year or two.
/ BACKHOES LETS SEE THEM #435
Nice to have the backhoe when you need it. Living on a steep property washout has become a problem. Decided to build a retaining wall and catch basin drained by a 6" covered drainage pipe.
Called in the big boy to help with the retaining wall due to the size of stones required. Even with my thumb the CK20 would not do.
Once the wall was complete though I took over filling in the pit and digging a 70 foot trench 5 feet deep to direct the water into the bush. Pipe was placed in the trench and covered with clear stone. I will now grade the driveway to direct runoff into the pit. The stone cover over the pipe will allow me to collect any water running down the driveway.
This was a fun project and just one of many that I was able to do thanks to some good equipment.
See pictures in next post
/ BACKHOES LETS SEE THEM #436
Tried to attach photos to previous post but operation failed. Hope this works.DSC_5833.jpgDSC_5837.jpgDSC_5835.jpgDSC_5838.jpgDSC_5843.jpgDSC_5844.jpgDSC_0248.JPG
/ BACKHOES LETS SEE THEM #437
3 days old:
First thing I did was dig a hole and pull a rock out with the hoe/thumb. Problem was, the rock ALMOST fit in the bucket, and the thumb made sure it did. I couldn't get the rock out of the bucket...it was crammed and jammed right in.
I had to get a large crow bar and pry it out.
/ BACKHOES LETS SEE THEM #438
LOL the stuck rock, but better to pry it from the bucket than from the ground..
3 days old:
/ BACKHOES LETS SEE THEM #439
3 days old:
/ BACKHOES LETS SEE THEM #440
3 days old:
Obviously you need to go put it back in and snap another picture.
2005 Airman PDS185S Towable Air Compressor (A64194)
2005 Airman...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
UNUSED FUTURE STB47 TELESCOPIC BOOM (A65055)
UNUSED FUTURE...
UNUSED FUTURE DHC-60" PALLET FORKS (A65055)
UNUSED FUTURE...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A65055)
UNUSED FUTURE MINI...
2000 Chevrolet Astro Cargo Van (A64194)
2000 Chevrolet...
