Attaching & removing 3 point implements
   / Attaching & removing 3 point implements #31
Nice job! Glad to see you made it work. My lever on my Deere is easily reached from back there if need be. I really don't understand why people have so much trouble hooking up 3 point implements. I guess growing up on a row crop farm is why I don't. Far as Saftey concerns, all our ag tractors since the late nineties(Deere) have had that option of a 3 point raise and lower on the rear fender. Our new Case/IH tractors also have a PTO bump feature as well. On the 3 point hitch, we have had quick hitches on the big tractors since the eighties. LUTT
   / Attaching & removing 3 point implements #32
Except for the make of tractors, your row crop experiences pretty much parallels mine including JD quick hitches in the late eighties. It was probably a two year conversion process retrofitting implement attachment points. Ah, the good old days. :)
Terry
   / Attaching & removing 3 point implements #33
Terry, I was pretty young then. I remember backing up to a few things to pick up with the new quick hitches and learning some new words! LUTT
   / Attaching & removing 3 point implements #34
John. Re: learning some new words'. Haha. And to think when we were young we thought we knew it ALL.
Terry
   / Attaching & removing 3 point implements #35
UPDATE:
After installing a prototype control mechanism and using it for awhile, I decided to fabricate a more robust system using a T handle, brake yoke and a chrome plated 32 Ford radiator support rod. I no longer have to struggle to get implements lined up. Obviously one has to be careful when moving/adjusting the 3 point while standing near the equipment while the tractor is running, but this works for me.
Here are a few pics of the final install including closeups of some of the parts used.
View attachment 382066View attachment 382068View attachment 382067View attachment 382065
View attachment 382071View attachment 382070View attachment 382069
Next project: Installing hooks and a receiver on the loader bucket and a hydraulic top link for the 3 point.
Looks good, but where can I find a chrome plated 32 Ford radiator support rod? Will a 34 do? :) Does it have to be chrome plated? :)
Thanks for the kudos. I know what you mean about putting on the finishing touches. Most times, it was too much of a hassle to go in and redo everything. I think the reason I did it this time around was because I already had the parts laying around and they were calling to me to install them... or something...
That's about how I'm operating. After "hoarding" all type of old parts I'm finding many projects that I'm able to complete because I have about the same precise size part I scavenged years, even decades ago. Just today I put together a small wood project (ramp for our Corgi) out of a 5yr old PC case and some 3/4 plywood that had been cut to the exact size needed about 15 years ago. Serendipity. :)
I think there are various Ford restoration sites out there where you could find one. The chrome feature makes it a bit more weather proof - plus it slides easier through the tubing clamp. ;p)
   / Attaching & removing 3 point implements #37
:thumbsup: Much better than the piece of 1" PVC pipe with an elbow to go over the lever, that I used on my old MF 240D.
   / Attaching & removing 3 point implements #38
To invent, you need a good imagination and a pile of junk.
― Thomas A. Edison
   / Attaching & removing 3 point implements #39
To invent, you need a good imagination and a pile of junk. ― Thomas A. Edison
That's encouraging news. I have the physical portion of that formula already, so I'm halfway there. Thanks. :)
Terry
   / Attaching & removing 3 point implements #40
If hooking up implements were easy women and children could do it. Then we'd never get any tractor time.
2013 Peterbilt 367 (A55973)
2013 Peterbilt 367...
(10) UNUSED SDLANCH 2.5CM X 3.5 MM RATCHET STRAPS (A57192)
(10) UNUSED...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
1408 (A57192)
1408 (A57192)
2009 Ford E-450 Super Duty Ambulance (A55852)
2009 Ford E-450...
2024 Bintelli ActivEV Pulse Electric Cart (A55853)
2024 Bintelli...
