What welder would be best??
   / What welder would be best??
I know most people use a chipping hammer, but I have been caught before because I chipped at a weld and it appeared solid but when I put it under load it broke. :mad:
I don't think the stick welder I have is capable of TIG. The everlast I am looking at has TIG capability.
I haven't welded (with my stick) any square tube thicker than 1/8in and I have welded 1/16in but that is mighty hard not to blow holes (I have done it though).
When I say inverter I am meaning SMAW inverter (pardon my ignorance).
How do you like your Everlast PowerARC's Shield Arc?
I don't know the general quality of Australian schools because I am home schooled (the best school in town).
I possibly am going to try out some Everlasts.
My grandfather taught me to weld, and the welder used to be my father's.
Thanks so much for your help
ferrari99
   / What welder would be best?? #32
Well your doing better than me. I burn through anything that thin using my stick welder. If you have a knob, switch, or separate plugs/hook ups to change to DC then it can do what you need for tig. Even with Everlast (nothing against them) you would still be out $25 minimum for the regulator and the cost of an argon bottle.
If you post your welder model, or a picture of it; someone can probably tell you for sure if it can TiG.
   / What welder would be best?? #33
37-years ago I use to Tig weld with this machine all the time.
I love them! Best arc for the money I have ever seen.:cool2:
Here are some photos of my welder, it australian made so I don't know if you can help.
   / What welder would be best?? #36
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=381788"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=381789"/>
The picture of the face looks like 225 amps AC/160 amps DC.
Edit: never mind, it's 50 volts 225 amp or 160 amps at 80 volts... so I am over my head, sorry; looks AC only to me, with 2 different voltages; no idea what that's for;
   / What welder would be best?? #37
It's pretty normal, on a standard AC buzz box you'll often see a high and low tap.
The low tap has the higher Open Circuit Voltage (OCV) and tends to run rod smoother and start easier.
   / What welder would be best?? #38
I learned at 14 years, but brazing first, then stick. I'm impressed. If I had a MIG when I was 14 I'da build much much more "stuff". You sure write well too, must have good schools down under!
If you keep with the stick, you will start referring to 1/8" (3mm) as "sheetmetal"
With practice, you will learn how to weld thin material with a stick welder, Have never owned a Mig and have no intention of getting one in the near future,
if I were in your position I'd be inclined to go for a good quality inverter.
At Orange & Henty field days Lincoln and others usually have a demo welder at their stand that you can try out. I have tried the inverter type welder and would have to say, that they are almost as good to use as the tractor or engine driven Lincoln DC welders. (they were and still are a great welder)
11' CONTAINER (A52706)
2015 Ford F-250 Knapheide Service Truck (A53422)
2015 Ford F-250...
2020 Club Car Onward HP Li ION Electric Cart. (A53424)
2020 Club Car...
2014 Ford Explorer AWD SUV (A55853)
2014 Ford Explorer...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2011 FORD F-250 Crew Cab 4X4 Pickup Truck (A53422)
2011 FORD F-250...
