JD 1020 3pt issues
   / JD 1020 3pt issues #1
rileyfcooper
Milford NJ
1968 John Deere 1020
I have a 1968 John Deere 1020 I bought several months ago. I am having issues with the 3 point hitch. It lifts all the way up but will only drop down a few inches even with weight on it. If left sitting it will eventually drop all the way down. Any ideas? The guy I biught the tractor from said it sat at his place for close to 10 years with almost no use. I was thinking either bad/low fli id might be the problem or possibly a stuck valve.
Any help would be awesome. I have 2 weeks vacation coming up and am hoping to get it working then.
THANKS
   / JD 1020 3pt issues #2
Put L/D control lever under seat in "D" if not already there and then try to lower 3 pt hitch.
Thanks for the advice. Unfortunately it didn't make the problem go away. Im going to try emptying all of the hydraulic fluid and adding all new. I think the tractor is low and I also think there may have some water in it. Hopefully that will help.
1992 Kenworth T800 Semi (A50514)
1992 Kenworth T800...
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A51219)
2012 INTERNATIONAL...
John Deere X740 Mower (A50514)
John Deere X740...
Komatsu PC138 (A50490)
