Buying Advice Narrowing the tractor selection pool
/ Narrowing the tractor selection pool #1
biodegraded
Lane County Oregon
MF 1754
This is my first post. Short background: I am buying a 10 acre property in the hills west of Junction City, OR. Seven of them are pasture and will be the main focus of my initial work. The place has been untended for several years. The last time I worked on a farm was 1976, so I'm rusty. Also, aside from being 40 years ago, it was 5000 acres, so the machines were of course gigantic and not relevant to my current situation. I have decided to go with Kubota based on their reputation and the simple fact that they have an apparently decent dealer closest to me. (Mid-Valley Tractor Company in Eugene.)
The reason for my post is to focus a tractor selection based on the vast experience on this site. Here are the tasks I know I need done:
  • Junk removal. Old farms accrue junk, it has its share.
  • Demolish (small) out buildings. There are several in stages from still standing to completely collapsed.
  • Dig holes. There will be much fence work needed. Also quite a few trees will be planted on the perimeter.
  • Blackberry thicket removal. My god those things get huge in Oregon! One is 15' tall by 60' across. No idea yet how to rid them.
  • Level paths. Driveway is 750' + side paths.
  • Mow pasture fields.
  • Two years later or so there will be some excavation.
Common tasks not relevant to me:
  • No turf.
  • No snow worth bothering with.
Attachments I know I'll need:
  • FEL
  • BB
  • PHD
  • Field mower of some kind. I don't have any experience in these.
I would appreciate suggestions on models to focus on. I have ideas from my own research of course, but I won't mention them to muddy input. Input welcome and thanks.
/ Narrowing the tractor selection pool #2
My first thought would be an L3800 if any are still available, or an L3901 for a basic machine. But then if you want nice, a few bells and whistles, then an L 3560 or even an L4060.
Sounds like you will be doing some grading, so be sure to get some rear remotes, 2 even 3 so that you can get top & tilt cylinders for your 3pt hitch and still have an extra for an implement cylinder.
Lots of different implements to make life easier. ;)
/ Narrowing the tractor selection pool #3
In tractor-speak a Field Mower is called a Rotary Cutter. The best known brand of Rotary Cutter is 'Bush Hog'.
A Rotary Cutter on the Three Point Hitch and a Ratchet Rake attachment for your bucket will handle those Blackberries, although control will take a couple of seasons. If you want to speed up control spray herbicide after mowing brambles down.
The Ratchet Rake is also good for minor grading of all sorts.
If you acquire a heavy enough tractor with a proportionately heavy FEL and bucket, a <$400 Bucket Spade attachment works very well for planting trees.
I have a Kubota L3560, my third tractor, and rate it a great tractor-loader. I was out rough cutting brush with my Land Pride (brand) RCF2060 Rotary Cutter all morning. Like so many others it took me quite awhile to realize what 'enough tractor' would be for my conditions.
LINKS:
http://www.ratchetrake.com/images/ratchet_rake_brochure.pdf
RCF2060 & RCF2072 Series Rotary Cutters | Land Pride
WELL COMPOSED FIRST POST.
/ Narrowing the tractor selection pool #4
If you get a machine with a SSQA (Skid Steer Quick Attach) front bucket, you won't regret having that option to add pallet forks and most importantly a grapple later on. A grapple is a great thing to have to clean up junk piles, move rocks and logs, and general brush and downed limb cleanup. Really saves on manual labor. Would you like to have a right hand that can pickup over a thousand pounds (or more) materiel and move it rapidly to another location without much effort.? That is what a grapple is, an extension of your hand. The key to versatility is SSQA on the front of your tractor. I don't know why they all don't come with it.. Just the money I guess.
The first big decision for me in the Kubota line was whether the go with the B series or L series. From what I'm reading here, L is the way to go. The ratchet rake looks like what's on the front of combines. Thanks for the replies so far.
/ Narrowing the tractor selection pool #6
Preceding the L3560 I had a Kubtoa B3300SU, purchased new. Good machine but I worked it too often too close to the margin in my woods work. Working a tractor beyond its capacity is not safe and it adds to maintenance. Also, the underside of the B3300SU, in common with all the B's, is somewhat vulnerable to brush in hard woods use.
The considerably heavier L3560 is much more stable. The telescoping and pinned Lower Links make hooking up implements relatively easy. The underside is well shielded and I do not hesitate to bull through the heaviest vegetation when using the Rotary Cutter.
I have SSQA option on FEL.
The L3560 is a 'keeper' for me.
/ Narrowing the tractor selection pool #7
btw: careful when taking down old shacks for safety & FLATS! best of luck
/ Narrowing the tractor selection pool #8
The advice about the SSQA is good! I was just in Ireland, walking in the countryside, and EVERY tractor I saw there had quick attach on front. Once you have/use it, you'll never be without it again. Weight is your friend, HP maybe not so important if you have time and not so much money. Smaller engines will get the job done, just not as fast. But for some jobs, a good choice. 30 HP or more would be what I would look at. A hydro tranny is good for loader work and worth the cost, IMHO.
/ Narrowing the tractor selection pool #9
L3800 or L4600 ... bigger is better than small in tractors. The hydro trans will spoil ya if you choose to go with it.. Drive both styles at the lot and see what ya like better.
Cant go wrong with Landpride implements. Their website and brochures are very well done and unlike most others they list a max cutting diameter on their cutters... Not all are created equal. They vary from 1" to 4" rated cutting size.
At least one set of rear remotes. they can always be used with longer hoses to use a front grapple etc.
/ Narrowing the tractor selection pool #10
35-40hp. I will second the grapple and ssqa recommendation. Like having a hired hand. If your thinking about haying the pasture you will need 50 hp. I have a L3400 and would be capable of all those jobs but sometimes I wish it were a bit bigger (mowing fields).
/ Narrowing the tractor selection pool #11
i would look at a l4600 kubota 4x4 fel.
/ Narrowing the tractor selection pool #12
If those blackberry patches are very thick just level your bucket about 6" off the ground and push. They will come out by the roots. Then you can pile them to burn, rot or leave for bird and small game habitat. I have one patch that is about 200' x 200' and another one even larger. I have cleared some but am disabled and can't keep up like I use to.
/ Narrowing the tractor selection pool #13
Had the same questions a couple of months back... brother really liked the B... thought the L3800 was a little big.
That all disappeared once he started working the L on the ranch... no regrets.
Thanks to all for the replies. I've been researching the information you've given. I think I've narrowed the selection down to a Grand L. My question now is, assuming I have enough weight for traction, how much HP should I get if I want to use 72" implements?
/ Narrowing the tractor selection pool #15
If you have a lot of field cutting to do in tall grass with a 6' cutter, I'd suggest an L4060.
Otherwise, the L3560 should be plenty - especially since you won't be snowbowing.
Hi BG, I'm not sure how to quantify how much field cutting is a lot. I will initially have 5 acres or so of grass that is over my head (I'm 6'3") which is also interspersed with blackberry thickets 12-15' tall. After it's tended the first time, however, I'll keep things under control so the demands will be kept in check.
/ Narrowing the tractor selection pool #17
Kubota Grand L's share a single Operator's Manual. Under IMPLEMENT LIMITATIONS/ROTARY CUTTER Kubota's official recommendations are:
(width/weight pounds)
L3560 72"/770 pounds
L4060 72"/926 pounds
L5060+L5760+L6060 84"/1,058 pounds
Baby Grand: As usual, good call.
/ Narrowing the tractor selection pool #18
Condsider optional (L2296) 72" Heavy Duty Round Back Bucket which comes with standard SSQA (Skid Steer Quick Attachment)
Standard 72" Square Bucket is 331 pounds. Optional 72" L2296 is 397 pounds. The extra weight is all beef.
L2296 is rock solid mount for clamp on attachments, I use both clamp on Bucket Spade and clamp on Debris Forks.
Ratchet Rake slides on and fits perfectly with no alterations.
I like mine a great deal. I had the standard bucket on my prior Kubota B3300SU.
L2296 LINKS:
http://www.tractorbynet.com/forums/...-kubota-hd-72-round-back.html?highlight=L2296
http://www.tractorbynet.com/forums/...y-vs-aftermarket-buckets.html?highlight=L2296
Hi jeff9366, I intend to go with someone's heavy duty bucket. That will be one of the most frequently used implements and I want it to last the rest of my life. SSQA is also a given for me. I'm interested in your back box blade - I gather that's a "rollover" type? Still researching BBs.
/ Narrowing the tractor selection pool #20
Yes, it is a Rollover Box Blade, mine is Bush Hog brand.
Rollovers are quite a lot heavier than standard Box Blades. The Rollover mechanism is simple and functional.
Rollover Box Blades require less adjustment in use than standard Box Blades, perhaps their major advantage. Rollover Box Blades are usually operated without hydraulic rear remote ports. (I do not have rear remotes.) ROBB learning curve is shorter than learning curve for a standard Box Blade.
Downside is they cost more initially as a stand alone implement.
Current producers: Bush Hog, Dirt Dog, A-B Eagleline, Woods/several brands
Obviously, ROBBs make fine rear ballast.
LINK:
https://www.google.com/search?q=ROL...ctorbynet.com&client=safari&rls=en&gws_rd=ssl
Hustler Super 104 104in. Zero Turn Commercial Mower (A61567)
Hustler Super 104...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(2) DIAMOND PLATE DBL AXLE FENDERS (A62131)
(2) DIAMOND PLATE...
UNUSED SDLANCH REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED SDLANCH...
2022 New Holland C327 Compact Track Loader (A63118)
2022 New Holland...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A62131)
UNUSED WOLVERINE...
