3R series rear remotes
/ 3R series rear remotes #1
EuroYanmar
Gold Member
Somewhere
Tractormatic
Good morning,
Here in EEC the JD 3R series are delivered standard with one rear remote only.
One more can be installed but the dealer told me it will be "electro hydraulic" .
I understand it will use a solenoid valve.
Is the situation the same in US ?
Have you got two true rear remotes or one true and one "electro hydraulic" ?
Thanks for your help,
Phil
/ 3R series rear remotes #2
I believe if your tractor has a cab, then that is your only option.
Open station tractors can have a 2 spool manual SCV.
Thanks for your answer Chevy.
The tractor is a rops tractor.
Onequestion : if you have got two spool manual SCV, how do you command them ?
Thought the front end loader joystick ?
Phil
/ 3R series rear remotes #4
The valve mounts to the right ROPS post, just above the right fender.
It has a lever for each spool. The part number here is LVB26035.
Chevy,
Your answer is clear like crystal.
Thanks a lot for having posted this picture and part number.
Phil
/ 3R series rear remotes #7
I have the same setup on my 4720 open station, and the install wouldn't be too difficult.
EZ Trail 3400 Gravity Wagon (A66285)
EZ Trail 3400...
100 Gal Oil Container (A64127)
100 Gal Oil...
Landhonor SGB-11-72W, 72" Grapple Bucket  (A62679)
Landhonor...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
Ficklin 435 (A64127)
Iranch High-End Tricycle (A64119)
Iranch High-End...
