Cub Cadet doing some strange stuff
/ Cub Cadet doing some strange stuff #1
wild4stangs
Attleboro, MA.
Cub Cadet HDS 2165
Hey guys, I have a 1995 Cub HDS 2165 with 485 hours on the clock. Lately after running for a while, when I shut it down, it will smoke a bit...:( Also after shutting down, on restarting 20 minutes later it will at time stall like it is fuel staved... Take a lot of cranking and messing with the choke to get her going again.:confused2: Once she is running all is good...:cool:
What do y'all thing is going on ?
This tractor has a 16hp Kohler vtwin...
/ Cub Cadet doing some strange stuff #2
check and see if there is a vent hole in gas cap,take straight pin and clean hole.Welcome from Wisconsin.
/ Cub Cadet doing some strange stuff #3
fuel shutoff solenoid is bad
find and replace
Yes I know the gas cap vent trick..I tried starting it with the cap off, that did not help.. Guess I will look into the fuel solonoid.. Any idea what that does
/ Cub Cadet doing some strange stuff #5
It turns off the gas so as to (supposedly) prevent that last gasp pop (backfire) when you shut off the engine. It seems to really do pretty much nothing. I had a similar problem with a lt1050, and the CC mechanic said to just open it up and snip off the end of the needle and reinstall it. That's what I did and it solved the problem. I still got no pop when shutting it off. If you do much trailering of the machine, it's good to install an in-line shut off valve, as the jiggling could cause flooding type issues.
OK, I will give this a try.. I will also install a shut off valve. My tractor backfires every time unless I let her idle for a bit first. Any ideas why sge is puffin a bit of smoke on shut down ?
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
(2) TRAILER TONGUES (A64280)
(2) TRAILER...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
2016 International DuraStar 4300 S/A Dump Truck (A61573)
2016 International...
