Goodbye 2305, hello 1025r!
/ Goodbye 2305, hello 1025r! #1
fpdsniper
Port Byron, IL
john deere 2305
Got my new Green ride a couple days ago. Still getting familiar with everything. I decided that I don't want to keep the Power Flow bagger system, so I posted it for sale. Anyhow, here's the old machine and the new one together:
/ Goodbye 2305, hello 1025r! #2
sweet! why the upgrade, if I may ask? have the 2305, too, and have toyed with it but haven't found enough reasons to pull the trigger. but, I'm not as informed as I should be on it yet. will the loader convert? what gains convinced you?
/ Goodbye 2305, hello 1025r! #3
Nice tractor!!!
When I was shopping for a subcompact 2 years ago, I was looking at used 2305s & 1026rs. The things that sold me on the 1026r were the following.
Much better seat suspension.
Drive over auto connect deck.
Position control on the 3 point hitch.
Being able to remove the 3 point hitch arms when using the mid mower deck, if you have the mechanical lift.
Folding ROPS.
/ Goodbye 2305, hello 1025r! #4
enjoy your new ride.
The 2305 is a 2007. The reason I replaced it is two fold. First, my wife owns an in home daycare business and we upgrade our tractor every few years for tax breaks. Second, my best friend owns a tractor business. He give me a "sworn to secrecy" deal on tractors. If I told you what I paid for it, you'd all hate me! Ha! Anyhow, I was just going to put a loader on the 2305, and he said, "Nah, let's put you in a 1025r at my cost". Couldn't say no! In the picture, I know the decks are are down. I took off the deck to wax it, apply Mo-Deck (I have no idea if it really works, but what the heck!) and play with the loader! I have the "optional" hydraulic deck lift, and kind of regretting that decision. I want my loader to work completely with the deck on! Oh, well. Is there upgrades available for the lights? I like as much light as I can get for plowing in darkness. Also, I took the mounts for the quick attach plow off my 2305, and held them up to the 1025r. It appears that all I will have to do, is get a small relief cut in one of the brackets to clear a bolt and my plow will fit! My hydraulic lines will be a little long, but other than that I should be good to go!
/ Goodbye 2305, hello 1025r! #6
There is an optional hydraulic valve & outlets for the rear of the 1025r. Part number BLV10351. You can then use the rear outlets for your mower deck.
/ Goodbye 2305, hello 1025r! #7
Units I have seen with the optional hydraulic deck lift have a valve on the fender. Out the Joy Stick Control works the loader. In the Joy Stick Control raises and lowers the mower. On most, tilt the control lever to the left and the deck raises, tilt the lever to the right and the deck lowers. The control valve is usually located just above the decal on the left rear fender show in the first photograph. The decal is a pictorial guide on how the valve works. The second photo show the hose busy area underneath the right foot, with a numbering system where the houses connect.
/ Goodbye 2305, hello 1025r! #8
The tractor pictured has a JD diverter valve. A JD diverter valve is not available for the 1025R.
/ Goodbye 2305, hello 1025r! #9
There is yet a third option for the deck lift. The part number (I think) is LVB26207. It has a completely independent electro hydraulic valve. Here is a picture of the kit from a thread over on GTT.
It seems like it would be the way to go...no hooking and unhooking hoses.
/ Goodbye 2305, hello 1025r! #10
Deleted, could not post link to where the Kit was actually installed with pictures on ****************.com. The blocked out portion is Green Tractor Talk. Com. The GTT words are all together.
/ Goodbye 2305, hello 1025r! #13
Nice tractor!!!
Folding ROPS.
Don't forget;
The top link is mounted to the frame, not the cheap aluminum gear case that was on the 2210/2305
The hydro has a cooler, not a cheap plastic fan on the drive shaft.
Fuel filler on the fender instead of the top of the hood.
/ Goodbye 2305, hello 1025r! #14
Only thing NOT improved is the price! In 2004 I bought my 2210 with loader, 62c deck, roto tiller, and rear blade all for $14k which I paid for with inheritance money. At the county fair this year sat a pretty new 1025r with loader and auto connect 60" deck bargain priced for the fair at "only" $20k !!! Looks like my 2210 will have to run another 20 years.... :(
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2009 PETERBILT 340 FLATTOP SLEEPER (A60736)
2009 PETERBILT 340...
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
John Deere 6110M (A60462)
John Deere 6110M...
Topsoil Trommel (A57453)
Topsoil Trommel...
