SSQA Forks
/ SSQA Forks #1
bacononeactual
Michigan
JD 770; LS G3038H
I need some inexpensive but sturdy SSQA forks for my new G3038h. I have been looking at the Titan Attachment brand on Amazon and those are the cheapest SSQA that I can find. Does anybody have experience with those or want to recommend another option.
/ SSQA Forks #3
I almost bought the Titan brand forks but found a new set locally for the same price. ($524. incl. tax). The Titan forks are on Ebay or Amazon and I don't see any problem buying them. Quite a few guys here have them. Here's some pics of mine. I recently added a hydraulic thumb for using on my forks and bucket.
/ SSQA Forks #4
I have the Titan 48" on my 4041 and I have been logging, clearing brush, digging stumps, and maxing the loader with them and haven't bent anything yet. I am going to mount a thumb on mine just like George. :)
eBay puts a new set up for auction every Mon night, I watched the price for several weeks a got the 48" for $586. With free ship. No complaints here.:thumbsup:
/ SSQA Forks #5
I have the Wildkat 42". Think I paid around $525. So far, so good. At the time I bought, I was torn between getting the 48" or the 42". I haven't yet encountered a situation where I wished I had the 48"
/ SSQA Forks #6
I have the titan 48 on mine
I used them on my skid steer to pick up some 4000 Lb columns the other day
/ SSQA Forks
Thank you for the recommendations. The Everything Attachments brand is only rated at 2000 pounds, so not much margin of safety there. Wildkat I can't find a link to purchase on their website. So far looks like Titan.
/ SSQA Forks #8
I wouldn't be concerned about the 2,000 lb capacity. It looks like a good match for your loader's 1,900 lb lift rating.
/ SSQA Forks #9
kco is right. The 2K capacity is a good match for your loader. I haven't compared prices recently but I was going to buy Titan forks until I found mine locally. My forks are regular skid steer forks rated for over 5K which is over twice my loader capacity. The Titan's will probably be your best bang for the buck and when I was looking they had free shipping, don't know about now.
/ SSQA Forks #10
If you want to make sure you won't bend your forks, get a set that can handle almost all of the loader's rated capacity on one tine. Why? If you have a max load, and it shifts all of the weight can wind up on one side. 2,000lb forks could very well bend if you put 1,900lbs on just one side.
/ SSQA Forks #11
I have the Titan bale spear with 60 inch forks and am very happy with it.
/ SSQA Forks #12
Agree, the 4000# are not much more $ , and you will use them for a lot of things you can't even think of now!! And you might get a bigger Tractor someday. :)
/ SSQA Forks #13
I have forks rated well over my loader's lift capacity. That said, they are much heavier than the lesser rated forks. That means I have less usable lift when I use my forks. I wish I could have found a 3k rated set of forks weighing around 300lbs, but that wasn't an option.
Either way you'll be happy.
/ SSQA Forks #14
I forgot to mention before that my forks are also rated for over 2x what my loader can lift. Bought them new from a place that sells new and used skid steers.
/ SSQA Forks
Good points. Also, I have been told that it's not hard to accidentally put the weight of the tractor on the forks and bend them that way if they are not strong enough. I do want, however, to find as light a set as possible to maintain as much of the lift capacity as I can, as I will need as much of the 1900 lbs as I can get.
/ SSQA Forks #16
I can state I have never bent my 1800 lb forks on either my previous tractor an L3400hst or my current tractor the Kioti DK35se. And I have moved and pried out of the ground some pretty big rocks. I use my grapple now much more, but the Construction Attachment's lightweight pallet forks have stood up to some abuse with no signs of wear or failure. Now I don't go out of my way to tear things up, but I do "use" things.
/ SSQA Forks #18
I have the Titan 42"s. If I had to do it over again, I'd buy the 48"s. You only have to buy them once.
It is really hard to see the tip of the 42"s from the seat.
The 48"s have a different rack. KWIKN, I'd prefer a larger more substantial rack to better hold loads and provide more chain attachment points.
As for the Titan brand, I wish they'd spend more time smoothing the cuts where the forks are supposed to slide. The cut is rough and it is difficult to slide the forks back and forth. And it is real, real easy to pinch fingers.
HSAOT: The 42"s do all that I could ask for.
Bob
/ SSQA Forks #19
I have had the 42" titans for almost two years now, no problems yet but you do have to grease the slides for the forks to slide easily for adjustment but you have to do that on them all. I got the 42" unit because I measured the forks here at work on the jitney and that is what they are and we can lift most anything, but if need be I could always take the fork extensions home for the odd time I might need longer those are like 6'+ in length. I think anything longer than 42" would be in my way and anything else would be too short but that is just my opinion and that and a buck might buy you a small coffee!
Patterson water pump (A59230)
Patterson water...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
2022 EZ-GO ELITE...
UNUSED IRLMC DELUXE MASSAGE CHAIR (A64281)
UNUSED IRLMC...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
Toyota 2FGC20 4,000lb. Propane Forklift. (A61572)
Toyota 2FGC20...
