x730 Vs. x750
/ x730 Vs. x750 #1
polo1665
Super Star Member
Ohio
Branson 3510H, John Deere X750
Hey All,
After 20+ years my Simplicity Sunstar may be on the way out. Its been a great mower, but has started to nickel and dime me over the last couple of years. A couple of days ago it developed a major oil leak that may have convinced me to send it out to pasture.
I stopped tonight and looked at a JD x730, nice tractor. From what I can see the only difference between it and the x750 is that the 750 is a diesel. My question is: Is it worth the extra $1,000 for the 3 cylinder diesel. This tractor is going to have to last me until I am in the ground, and I am wondering if the diesel is more likely to last longer than the gas engine.
Thanks for any info or suggestions.
/ x730 Vs. x750 #2
Unless you provide more information it will be very difficult for anyone to give a good answer. Things like, what do you want to do with the unit? how much area to maintain? Is it flat / hilly or ? Do you ever need AWS? AWD? Do you have other diesel machines? How many hours on the Simplicity? Do you expect the new one to be similar hours?
Just a few ideas for additional info.
/ x730 Vs. x750 #3
Or...are you 50, 70, 110? ;)
/ x730 Vs. x750
Already have a larger diesel machine that I use for loader, backhoe, tilling, plowing and logging. This one is going to be used exclusively for mowing about 2.5 acres, mostly flat, with a some side hill. I surely don't need 4 wheel steering and really don't need 4WD, neither of the two models I mentioned have either of those. Sorry I wasn't more clear, but the reason for the post was to ask if the diesel engine would be worth the extra grand from a longevity stand point.
Thanks
/ x730 Vs. x750
Jay, I'm 49, and if the JD only makes it 22+ years like the Sunstar did, well then I'll hire the mowing out for the other 20 years til I croak.
The hour gauge on the Sunstar quit working at 700 hours, that was about 6 years ago.
/ x730 Vs. x750 #6
IMHO go diesel.I bought a JD X740 (2 wheel drive)with the diesel option and 7 Iron deck.It sips fuel compared to my Ingersoll with the 4020 onan 20hp gas engine.
/ x730 Vs. x750 #7
:laughing:
:thumbsup:
/ x730 Vs. x750 #8
Thanks
I wanted a dedicated diesel mower to reduce the amount of ethanol-free gas I had to buy. It's expensive and not as widely available. I know that some say it's not a problem to run 10% ethanol in JD gas engines, but I knew I wouldn't want to do it. I ran ethanol-free in my X500.
Speaking of X500s, you may wish to consider one, or something else in the X5xx series. For two to three acres of mostly flat land to mow, even the X500 is arguably overkill. I only mention this because it seems you are not opposed to a gasoline engine. JD is quite proud of the X7xx series, and for your use would most likely be unnecessary. The X500 is very stable and plenty powerful.
/ x730 Vs. x750 #9
Thanks
Based on above comments, I would go diesel.
/ x730 Vs. x750 #10
In my opinion get what you want, the 1K is a wash. The 1K extra for the diesel buys a fair amount of gas, but the diesel has a cool factor and will likely return that 1K when you part with the machine.
/ x730 Vs. x750
Hadn't even thought about the ethanol situation. Guess that's another reason to go with the diesel. I agree about the overkill, but I really want the 60" mower. Thanks for the insight:thumbsup:
/ x730 Vs. x750
I like the way you guys are thinking. Looks like diesel is the way to go. Chances are that I will be joining the group of proud JD owners.
Thanks for your time and patience.
/ x730 Vs. x750 #13
Ethanol with a fuel injected engine is not a problem. You don't even have to treat it. And I ran ethanol gas through my carbureted 425 for 19+ years. Never had a problem. Never touched the carb. I did start treating the fuel the last 5 years or so, but not so much for the 425 but more for the other machines that share from the same cans. You don't need the diesel. Get it because you want it, but you don't need it.
/ x730 Vs. x750 #14
I fully agree. Go for it!
/ x730 Vs. x750 #15
The diesel motor will out last the mower deck if you service both properly. The gas motors in the older 4x5 series would last 1500 to 2500 hrs on the average. But the diesels would run 4000 to 5000 average, but the bodies and decks were pretty well gone.
/ x730 Vs. x750 #16
I honestly think gas will eventually be phased out, it is simply to inefficient, and the ethanol issue will only get worse with time as they increase content percentage.
You already have diesel equipment, go diesel. I intend to buy everything diesel that I can from here on in. It's just too good to ignore.
/ x730 Vs. x750 #17
Go diesel and a big deck. It is nice to get fuel from one source and the diesels in the X700s are fuel sippers. I never heard of any complaints about the amount of fuel they use.
/ x730 Vs. x750
Happy day today. On my way up to the dealer this morning with check in hand. They will be prepping the X750 with the 60" quick attach mower deck. Hopefully I can get delivery scheduled for Monday!
Thanks for all the support!
/ x730 Vs. x750 #19
Good for you,your gonna love it.
/ x730 Vs. x750 #20
:D
Congratulations on your decision. This comment may be too late since it is now afternoon, but consider this. Get your best cash price and then ask about the 0% finance for 60 months. Give them 10% down and balance (probably less than $200/month) over 60 months. Put the cash under your mattress (<-; for a rainy day. You may not even miss the $200/month and will be like a FREE lawn tractor.
2024 John Deere 8R 410 Tractor (A63109)
2024 John Deere 8R...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63118)
2023 Kubota...
