New trailer build
/ New trailer build #1
pjb09
Lakelands, Nova Scotia
BX25
Decided I needed a trailer to move my BX25 from one property to another. Borrowing and renting proved to be a pain.
To move the tractor and a piece of equipment or two I figured a 16' car trailer would be about right. Searched the net and found a set of plans I liked. Had them in PDF format in about 5 minutes for $40.
Ordered steel in the morning and started the next day.
It's been a lot of fun. Here's a few pictures. 20140521_132628.jpg20140521_143641.jpg20140526_143026.jpg
/ New trailer build #2
Oh that will be a fun project!:cool2:
Looks mostly like tube, and some C-channel?
/ New trailer build
It's 246. 125 for the rails and A frame, 2x4x. 125 for the cross members and 2x2x3/16 for the deck support rails.
/ New trailer build
Sorry messed that post up. Rails are 2x6x. 125 tube
Used the fork lift to keep the welding as easy as possible.
/ New trailer build #5
So how does that ground set up work with the rubber pads on the end.:D
I'm assuming you corner squared it. Once it's all welded up, drill small holes in the bottom corners of the tubing to let any moisture drain. It's especially important for the decking screws cause you don't want internal rusting.
/ New trailer build
Thought somebody would notice that. Other side of clamp has no rubber pad. Can't remember why I did that, but it worked fine. Decking is 3# expanded metal, so no decking screws.
/ New trailer build #7
I'm curious what the flat bar on the tubing is for, just to hold up the expanded metal? Interesting trailer design. :confused:If you use expanded metal for loading ramps, it has better slip resistance one way over the other. You can tell just buy sliding your shoe on it.
/ New trailer build #8
Did you consider installing brakes on both axles? I recently added brakes to the second axle of a 16' trailer I use for my tractor (not as nice a design as yours :c). Sure makes stopping better and they are not expensive.
bumper
/ New trailer build #9
How much do you have in materials vs what a factory build one costs?
/ New trailer build
The flat bar keeps the deck support level with the 3/16 thick angle supports. The maximum span for the 3# decking is about 22 inches. It should be pretty stiff. The ramps use angle cross members.
/ New trailer build
bumper
Most of the time I won't be carrying more than 3500 lbs and a single brake axle behind my 1 ton dually should be fine. If I find I want more brakes on the trailer I can add second set of brake drums. Second axle has the brake plates in place.
The trailer design came a company in Australia. Had to change the A Frame. They use a 32 degree angle instead of 50.
/ New trailer build
How much do you have in materials versus what a factory build one costs?
I have about 2700 into it including tax. Local price including tax would be close to 4000.
I saved almost 600 by buying axel, brakes, fenders, coupler, lights etc from Cerka in Ontario instead of locally from Princess auto
/ New trailer build #13
Arc welds suggestion of drilling weep holes in the bottom of the tubes is a really good one!:thumbsup: He always has good ideas!:cool:
/ New trailer build
I have capped all tube ends and there won't be any screws piercing the tube. Built indoors. Welding should have driven most moisture from inside the tube. I can still drill if necessary, but won't that introduce a new entry point for moisture?
/ New trailer build
After welding the spring hangers I noticed a 3/4 draw in the stringers. Not good! The plans called for stitch welds between the 2x6 rail and the 2x6 angle. I did a continuous weld, and monitored the draw as I progressed. Started in the middle and worked my way to the ends. By the time I had a continuous weld all the way both rails were perfect.
/ New trailer build #16
If you are going to have brakes on one axel they need to be on the rear axel. Brakes on that style spring set up shifts weight to rear axel. Ask me how I know. I added brakes to front axel of mine and you could lock them up and not feel the truck slow down at all. Did not think they were working until I saw all the tire smoke in the mirror.
DRL
/ New trailer build #17
That's one of those catch 22s. If you live in an area with lost of condensation I would sure think about weep holes.
A Few more pictures.View attachment 379535View attachment 379535
I really like to back step my welds, skip around a lot. An place opposing welds when I can, to help with distortion
/ New trailer build
Wouldn't fit thru doors, had to out it on a dolly and use forklift to pull outside.
/ New trailer build
DRL
I've heard both front and rear axle from a number of people. Decided to investigate further. Called my axle supplier. They (Cerka - axle manufacturer) and Dexter both say put it on the front. Weight shifts to front on braking and you want weight on brake axle. I know this is a big debate on other forums, but when the manufacturers say put it on the front I have to put it on the front.
/ New trailer build
That's basically what I did except I concentrated in the middle first so I could moniter the progress of removing the warp. I figured when I had it almost all out I would switch back to stitch welding. It took continuous welds both sides to remove the warp. It can out perfectly straight to my relief. It's amazing how much draw you can get from mounting three spring hangers.
2016 Ford F-550 4x4 Venturo ET25KXX 2 Ton Crane Service Truck (A61573)
2016 Ford F-550...
2017 Chevrolet Express 3500 12FT Box Truck w/ Liftgate (A61573)
2017 Chevrolet...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
2018 INTERNATIONAL LT625 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2018 INTERNATIONAL...
Pallet of Hay Tedder Tires (A64119)
Pallet of Hay...
