Electrical relay?switch question
/ Electrical relay?switch question #1
chopped
New England yankeee
Hello, I hope the vast knowledge of the members here can assist me in my search for the electrical part i need.
Im looking for a relay or switch. not sure which it would be called.
I want to have 120 volts input , and that would disconnect another 120 volt circuit.I find some that would complete the connection but hard to find one that would disconnect .
Anyone have any ideas ? like what I should be searching for?
Im thinking about a 15 amp load on the one id want to dis-connect.
Thanks
/ Electrical relay?switch question #2
So you want a relay that will turn something off, when it's energized?
Most relays will do this. They have contacts that are normaly open (NO) as well as contacts that are normaly closed(NC). Usualy there are three switched contacts. One is common, and will change which of the other two it is connected to when the relay is energized.
You can easily identify such a realy as it will have five connections. Two for the coil, one common, one NC and one NO.
They will be listed as SPDT:
Single
Pole
Double
Throw
Single pole means that it has only one switched circuit.
Double throw means it can connect the common to one of two other contacts.
/ Electrical relay?switch question #3
Look up Contactor relay. That's what you'll need
Thanks for the reply yes Im wanting to have a relay or switch that carrys the black straight through.......BUT when the 120 from another circuit energizes it then the contacts open the black is dis connected. hope this helps. I found this one but it looks to energize the terminals and not dis connect them. Ill check the contractor relay also.
90 341 2 Pole Switching Relay 120 Volt Coil 2PDT 12 Amp Cont 125 Vac | eBay
Single
Pole
Double
Throw
/ Electrical relay?switch question #5
a little confusion on what your trying or wanting to do, I think,
what is the application, kind of sounds like your wanting to make an automatic transfer switch type thing,
where two different circuits feed one item, but only one feeds at a time, and when the second one is energized it drops the first,?
If I am understanding you want a Double Throw contactor and the coil powered by the line that you want to sense the line when energized,
/ Electrical relay?switch question #6
That relay should work. See the two tabs in the middle, those go to the coil. And the set of three tabs at each end, those make up the two poles of the relay. Each set of three will have one common, one normaly open and one normaly closed. Use the common and normaly closed contacts (from the same side) and you will have what you want.
ill try to further explain. The application is for two seperate heating duct damper motors. One is on the wood furnace and the other is oil furnace.My goal is to have the power when the oil blower comes on to open the oil duct and also to close the wood furnace one.But Id like it to be set up to be able to run both units. So the plan is to use a relay or switch of some sort to run the black wire through, But when the wood blower comes on It would send 120 volts to the relay and that would "break" the black. which would open the wood furnace damper and allow air to blow from both units.
Further ,I think I want a relay that is 'normally close' and the 120 volts would make it 'open.
In your thoughts Dan if you were to use this relay , there would be the 120 volts coming into the relay to 'disconnect the two flow through blacks? Thus making the two center terminals the 120 volt white and black from one source? Id also have the other cicuit that Im looking to break.which terminals would be closed (normal) and then be broken when power was applied to the two center terminals? Thanks hope I ding make it to confusing..
I think I understand what you mean now that I look at it further..So the 'coil' 120 goes to the center and then just find two terminals that are normal closed, and when the center is powered then it should open the other two terminals? If I understand ..
/ Electrical relay?switch question #9
A double throw relay has a NO and NC contact one is in contact with the common at rest ("normal") the other is in contact with the common when the coil is energized.
If you need two sets of switches like this, say to reverse a DC motor, you would get a double pole double throw (DPDT).
/ Electrical relay?switch question #10
Yup... that's it.
/ Electrical relay?switch question #12
Yup. No doubt. But that's more relay than you need. $20 is a lot for a relay. That one could handle a lot more current than you will need. You should be able to find a relay for $3 that would suit your needs.
Just look for a relay that has SPDT switch action, has a coil voltage that you need, and is rated to switch the amps that your load will draw.
Thank You How about this one?
Packard PR294Q SPDT 120V General Purpose Fan Relay 90 294 | eBay
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
TAYLOR-WAY 200052 - 21' DISC HARROW (A64277)
TAYLOR-WAY 200052...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
White 6182 12R Planter (A66285)
White 6182 12R...
