Remove your hitch.
/ Remove your hitch. #1
Diamondpilot
Super Star Member
Daleville, IN
Jinma 254/284 Ford 861 Powermaster at work
So today i had a guy stop by my shop. A friend of a friend sent him over. His truck is a 2008 Dmax 2500. Anyway, he needed to get the 2" ball out and switch over to a 2 5/16". He said it was stuck and had been in there for 6 years. Anyway, we put a chain around it and a couple of good pulls from my F350 popped it out. Good thing he didn't tow anything serious with it.
Guys will argue it's ok to leave them in but this is probably the 10th one I have dealt with that says otherwise.
Chris
/ Remove your hitch. #2
That's why I Neversieze mine and pull it when not using.I am always banging into it if it's in the truck.
/ Remove your hitch. #3
that says 'salt' all over it to me.
He should have painted it... paint don't rust. :)
/ Remove your hitch. #4
Good point, but I really never understood the need to list the make/model of vehicles involved when it has little to no relevance to the issue . . . just had to get that off my chest.
Back on topic . . . adequate paint coverage to help prevent the start of rust is hard to achieve inside a small tube, not to mention some of it most likely gets scrapped off when installing/uninstalling. I don't recall the brand of hitch, but I came across one that was actually sealed off on the backside, and I wasn't to keen on that design because I believe it had the potential to make a situation like this more likely to occur or even make it worse!
/ Remove your hitch. #5
The receiver is probably weaker, too. The insert rusted all the way through.
Bruce
/ Remove your hitch. #6
I think anyone over the age of 14 should be able to get paint inside a tube.. a short tube at that. and painting tounge is nothing more than a dip coating, since they are loose enough to rattle around anyway. ( ie. truck bed liner or other rubberized paints are great for this sort of thing.
Add in a layer of grease and you have a pretty good amount of rust protection.
/ Remove your hitch. #7
The hitch is probably older than the 2008 truck.
/ Remove your hitch. #8
could be. don't look like a reese.. almost looks like a drawtite
/ Remove your hitch. #9
It does not look like a very robust hitch in the first place. Last time I saw one like that it I think it was limited to 5000# max.
/ Remove your hitch. #10
That is the nice thing about solid bar ball carriers. They will never rust through and are pretty darn strong.
/ Remove your hitch. #11
It seems the newer receivers ('13 GMC and '12 F150) are made looser so they wont get rusted in. The problem is the hitch insert then clunks around a bit when in use.
/ Remove your hitch. #12
It seems the newer receivers are made looser so they wont get rusted in. The problem is the hitch insert then clunks around a bit when in use.
I slather my receivers with anti seize compound and have never had a problem getting the hitch out
/ Remove your hitch. #13
I had the hitch seize up on the my old pickup-it went with it when I traded it-and bought a stainless hitch!
Will
/ Remove your hitch. #14
We switch back and forth between a ball and a pin hitch (landscape trailer or haywagon), so we take it out every time.
Aaron Z
/ Remove your hitch. #15
I have the same problem on an old 87 deck truck I picked up a month or so ago, the receiver tube had a plate welded over it as well, I have been spraying it regularly with Fluid film and WD 40 and can now manage to move it a millimeter or two from side to side with a hammer, I hooked onto my old 12 foot heavy harrows and drug those around the field for half an hour hoping to snag a badger hole and pop it out and it didn't budge... next step is giving it some heat I guess.
Cheers
Roger
/ Remove your hitch. #16
So today i had a guy stop by my shop. A friend of a friend sent him over. His truck is a 2008 Dmax 2500. Anyway, he needed to get the 2" ball out and switch over to a 2 5/16". He said it was stuck and had been in there for 6 years. Anyway, we put a chain around it and a couple of good pulls from my F350 popped it out. Good thing he didn't tow anything serious with it. . .
Chris
No worries. That ball mount should handle anything he CAN tow with a Dmax.
Now, if that was on a F-series, . . . :D :stirthepot:
The point was it was so rusted a 2500 Diesel truck could not free it.
I once lifted the rear end of a van off the ground with a backhoe trying to remove a sized little 1.25" class 2 hitch with no luck. Just ended up having to buy a new hitch.
Chris
/ Remove your hitch. #18
Chris ..............we know what your motive is on just about every post . :cool:
I keep mine in because with six months of winter up here , at least once every winter someone slides into me at a traffic light......I prefer no damage on my vehicle.
/ Remove your hitch. #19
I believe they are illegal to leave in full time in Saskatchewan for that reason ,the guy behind won't be as lucky but if he just tapped your bumper neither would be hurt.
Every year? Sounds like you people need to learn how to drive.
By the way they are illegal to leave in when not in use in most areas but rarely it's enforced by the law man.
Chris
Bulk Lot - (3) Pallets of Electric Motors & Pump Components - Selling as One Lot (A63689)
Bulk Lot - (3)...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2014 Nissan Frontier Ext Cab Pickup Truck (A61573)
2014 Nissan...
211299 (A62131)
211299 (A62131)
2022 TEXAS PRIDE DUMP TRAILER (A65643)
2022 TEXAS PRIDE...
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
