John Deere 2120 Shift Question
/ John Deere 2120 Shift Question #1
bigblock76
Little Britain, Ontario
John Deere 2120, John Deere 3140, John Deere 2950, John Deere 7700 Combine, John Deere STX38
Hello Everyone,
I had the clutch, pressure plate etc done at the dealer last fall and have only put on 30 hours in the last 8 months on the tractor.
My question is should I not be able to shift the range selector from 1 to 2 or from 2 to reverse without having the gears shudder / grind while leaving the gear leaver the same.
Example: Driving forward in range 1 gear 8. Clutch down all the way, break to a complete stop, change range selector from 1 to reverse while the clutch is still down and not having it grind?
Or driving in range selector in 1 gear number 6 and clutching down all the way, at a full stop and going from range 1 to range 2 without griding and leaving the gear leaver still in number 6.
Am I doing something wrong here? Tractor doesn't have a hi-lo shifter.
M
/ John Deere 2120 Shift Question #2
Hello Everyone,
Yes if clutch is properly set and adjusted.
/ John Deere 2120 Shift Question #3
Gearbox on JD2120 NOT SINCRONIZED and will grind a little . Check that your clutchpedal freetravel is adj to 40mm/11/2 inch
Hello Everyone, I did the adjustment and turned the clasp in a few turns to get it down to about 1/2" of free play. I have to say it did seem to help and make a noticeable difference, but sometimes I still get some chatter. Is that still normal?
2025 JMR 4x8 Forklift Safety Basket (A61567)
2025 JMR 4x8...
2016 VOLVO VNL630 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2016 VOLVO VNL630...
New/Unused Landhonor Quick Attach Hydraulic Pallet Forks (A61166)
New/Unused...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
APPROX. 12'X25' GOAT PEN (A62131)
APPROX. 12'X25'...
2018 Ram 3500 4x4 Utility Truck, VIN # 3C7WRTCL0JG387527 (A61165)
2018 Ram 3500 4x4...
