Buying Advice m6040
/ m6040 #21
That's a nice looking unit. Before you pull the trigger on this unit be sure to run the A/C & heater. For that price EVERYTHING on that tractor should be as a new unit. There should be no dust bunnies in the corners even - ha,ha.
/ m6040
If it works out i wont pay new price for a used tractor.
/ m6040 #23
at this point, aside from cab decision, you might go to K's site & pull up (if possible) mx specs & 6040's specs just to see what you would gain in terms of stepping up from the mx. the M series is bit heavier, better trans/shuttle. not all that much hp. someone once said, choose your model, then sgo up one & buy. not suggesting buying anything, just study specs which is what it comes down to when narrowing between 2 (or more)choices ya got the bug!
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
UNUSED WOLVERINE MAD-12-12D 12" MINI HYD AUGER (A62131)
UNUSED WOLVERINE...
Coats 5060AX Rim Clamp (A63118)
Coats 5060AX Rim...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
UNUSED JCT 84" HYD ROCK GRAPPLE BKT (A62131)
UNUSED JCT 84" HYD...
Coyote Renegade Trailer (A63116)
Coyote Renegade...
