jwmorris
- Joined
- Oct 3, 2007
- Messages
- 1,188
That is pretty much what my $300 one is like.
so you got a steal deal...That is pretty much what my $300 one is like.
When a 1700kg compact pulls 2.5 yard (or 1.9m3) like in that video, my 3.5 ton 5718 should pull a 4m3 (5.5 yard) scraper, so when i rent it to a local (less skilled) farmer he can handle it nicely with a 4.5 ton 100hp 4wd... Within now and 15 years i'll build one, when everything else i want to build has been built...
that tractor should have no problems filling it within a tractor length... when using one for land levelling here, it would only scrape thin layers on a hundred yard length which requires less traction. Contractors are using way bigger scrapers for land levelling, an 11m3 pulled by a 10 ton NH T8.330 is a bit less than a ton per m3 (about a metric ton per yard) . Most people think Holland is totally flat, but yet farmers here wish it to be millimetered as a billiart table:This is the one I found.[/url]
