Hydraulic hose sizing
/ Hydraulic hose sizing #1
UncleBuck1
Baton Rouge, LA
2011 MF 2660HD; 1964 JD 4020 (may she rest in peace)
Okay, the old saying is that there's no such thing as a stupid question... but I will admit that this one may be.
I'm currently running a front end loader on my JD4020 off of the rear remotes (6gpm flow) and I want move the supply to the rockshaft hydraulic circuit to free up my remotes. The rockshaft line that I will be tapping into (replacing an elbow with a tee) is supplied by a JIC-8 nipple, which I understand has a 13/32" i.d. I plan on installing an 8gpm flow restrictor to keep the flow comparable to where it is now.
The existing pressure hose is 3/4" i.d. Can I bring the existing pressure hose to a hydraulic shop and have them install a JIC-8 hose end, or do I need a smaller i.d. hose that more closely matches the port size?
/ Hydraulic hose sizing #2
or have them make a short hose in 1/2" that goes between the 3/4 and the jic-8 ...
then you can always "go back" to the stock setup if you ever want to.
With the new hose routing the supply line will probably be almost 3 feet shorter than it is currently so an adapter hose or fitting isn't much of an option (and I've never seen a quick-connect to JIC adapter); I'm going to have to either shorten or replace my existing pressure hose, and the decision on which route to go depends on whether hose i.d. makes a difference.
So... can I surmise from your answers that the difference in hose i.d. isn't an issue? I'm still struggling trying to sort out what is and isn't important in hydraulics!
/ Hydraulic hose sizing #5
Most if not all hydraulic shops will not install ends on used hose. The liability is not worth the risk.
Hose ID matters for flow Vs pressure drop. If this is intermittent flow the ID is not as critical.
/ Hydraulic hose sizing #6
I can't help you on the ID size but for what it's worth, I just bought 2 hoses 3/8" id for $50 -- one was 14" and the other 41".
/ Hydraulic hose sizing #7
Tractor Supply lists ready made 3/8" Hyd. hoses (18" and 48") both for about $25.00
Check your local TSC store for an adapter fitting from 3/4" to JIC. Not sure but is this the fitting you need. They have others.
http://www.tractorsupply.com/webapp...ory_rn=&top_category=&urlLangId=&cm_vc=-10005
/ Hydraulic hose sizing #8
/ Hydraulic hose sizing #10
/ Hydraulic hose sizing #11
Hyd. hose has a shelf life, usually about 2 years. That's why it's good to have hoses made as needed. You don't know how long they've been sitting around. There are some fitting sizes that are made to work with smaller size hose. My loader uses fittings that are normally used with 1/2" hose but my hoses are only 3/8". No problem, they make the fittings to fit on 3/8" hose. They had to cut the old hose to see what size it was because there were no markings on it.
1996 International 4700 (A64127)
1996 International...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
