Total welding newie here
/ Total welding newie here #1
Carol in CA
Member
Escondido, CA
John Deere 400
I want to learn how to wire weld. Suggestions for on-line instruction? Tried to find a mentor. No luck. Classes offered are for folks looking to make a career of welding. I'm just a wannabe with a few hobby projects.
Also looking at the newest Everlast weld. Thoughts?
I just picked up a lumber rack for my truck that needs work. Would that be a good beginner project? It needs legs and two crossbars. Welding quote was $250 including material. Yikes!
/ Total welding newie here #2
I suggest you stay away from the 120-volt Mig machines! Get a 220-volt machine. For general fab work .035" wire is really nice size to use.
/ Total welding newie here #3
Here's a short clip from some of the best made welding videos out there
GMAW Mig Welding | Wire Feed Welding - YouTube
Each course (mig, stick, gas, etc) runs about $25, the photography is clear enough you can actually tell what he's talking about - if that's not what you're looking for, here's a free site for ANY type of welding by a guy who does it all
Welding Tips and Tricks - TIG, MIG, Stick and a pantload of other info
Or, you could move to Tacoma - Shield has been known to help a newby or three :D ...Steve
/ Total welding newie here #4
I'm using a 120v unit and I've worked on my box blade on my Mahindra and the mower deck on my garden tractor along with other things. I've got 220 in my outside building, but since I only work on light items I saw no reason for a 220 unit. Besides everyone has a 120 volt outlet if you have to help someone.
Sent from my Galaxy Nexus using TractorByNet
/ Total welding newie here #5
<snip>
I'm surprised no one told you no for a beginner project. I've no experience and am pretty darn sure you should not make your first project something that might damage something or someone if it fails. A lumber rack under load at highway speed is such a thing.
/ Total welding newie here #6
watch the videos ( youtube etc ) watch ARC and MIG ....
check out some of the trade schools or continuing education classes at community colleges ....you have a ready made "class project " for any of them ( offer to pay for materials if the class does the welding ) ... buy a helmet and offer to sit and watch while they do the "work" .... the class instructor will make sure it's done right .....
/ Total welding newie here #7
ChuckE2009 is an enthusiastic fellow who can show you some good tips.
/ Total welding newie here #8
I learned on a 110 volt Lincoln SP 135 running flux core .035 wire. Good and simple way to practive and perform some lighter tasks. I have several welders and still use a small 110 volt mig machine fairly often. The last time I used it was welding some supports on my satellite dish so it would not wobble in the wind. Threw it in the bucket and plugged it in and we were good to go. Plenty of good machines out there with some of the nicer ones being able to operate on 110 and 220v outlets which as was said earlier can be important as you more to bigger proejcts.
Another way to learn some important basics is to buy a simple oxy welding outfit and learn to control heat and add material. I know some guys who got a oxy welder and a handful of coat hangers to learn basic welding out on the farm.
There is also a book called the "welders handbook" by Richard Finch that is a good piece of information to have. Touches on the basics of each process without turniing it into a novel.
/ Total welding newie here #9
I will second the 220v idea. I have never had a machine that had more power than I could control (have a 565 amp machine that I can weld sheet metal with) but most of the 115v wire welders peter out around 1/4" and even then only good for 30% duty cycle.
Easy to learn on more machine than you need, much harder to learn with a machine you are asking more out of it than it can do.
/ Total welding newie here #10
A lumber rack is a good first project. That said, you need to learn how to do a proper weld before you jump into your first project. I think you'll need at least a couple weeks practice. I'd also recommend getting a 220 machine so you have the capacity for bigger projects once you get more proficient. Solid wire with shielding gas is fairly easy to learn and has way less smoke than flux-core. People on here seem to really like their Everlast welders and Mark is very helpful to boot.
/ Total welding newie here #11
I can also recommend those sources of information. I bought the stick welding DVDs, and welding tips and tricks has the best videos on YouTube.
/ Total welding newie here #12
This is good advice. Mig welding is the best process for making a great looking weld that has little strength. You can lay down a beauty with a MIG that has less strength than a "booger" with a stick.
Die penetrant tests exist for this exact reason.
/ Total welding newie here #13
Regarding the common thought on 120V welders....
There is a lot of confusion about this.
First, most 120V welders are about 20% duty cycle at 90 amps, even though they are rated at 140 amps. The maximum amps are theoretical based on wire speed and in most cases require super high input amps to reach maximum amperage.
Second, the 140E i-MIG we sell from Everlast is capable of 140 amps at 35% duty cycle when compared to a Miller or Lincoln equivalent transformer model, that's a huge difference. 140 amps is considered enough to make pass after pass with a 1/8" 7018 on pipe and other structures...it should be enough for MIG...though there are admittedly different variables at play. But being able to get more practical heat out of an inverter changes the equation a lot...by 50 amps or more. Sure 90 amps is low, and really doesn't build enough heat for heavy weldments, but 140 amps is doable. Add in the 100% CO2 ability, penetration and heat will be hot enough for most any multi pass welding that most people will ever do.
I guess it is going to be open to debate, but I think inverters are a game changer in this. And with ours at less than 400.00 with shipping, (TBN pricing) I think people will be willing to give it a try.
/ Total welding newie here #14
When it comes to Mig welding, I' am just like Tim Taylor on Tool Time. MORE POWER! :laughing:
So guys, anybody in San Diego county wanna show me how and mentor me a bit?
/ Total welding newie here #16
Carol I would love to help you, but I'm way to far north:(. Maybe think about running an ad in your local Craigs list. Few years ago there was a guy here that did that. I don't remember what he charged. There is nothing better than one on one instruction!;)
/ Total welding newie here #17
I've been welding with GMAW (most people call it MIG) for over 40 years, and like others have said, there's no substitute for power. I worked my way through college using 300 amp Miller welders on chipper box 16 ga. steel and they worked great. Crank 'em up and you can run spray transfer on some really heavy plate. But that was at a company and in those days they were $3000+ machines. When I retired I wanted something I could fix a tractor with and not break the bank, and I ended up with a 180 amp Lincoln Power MIG 180C. I just finished a quick mount adapter for a pair of fork lift tines, and the machine stayed on the highest settings for every weld. Most of the steel was over 1/4" and all the welds were multi pass. It did the job, but I really wish I had one of those old transformer rectifier Millers and a hookup with enough current to drive it.
As far as training goes, find a community college that offers adult education classes and sign up. You'll get maybe eight or ten weeks of one night a week for a few hours and you'll learn everything you need to know. GMAW, especially with the modern machines with easy to understand presets, is very easy. Mine has a chart on the door that covers the wire feed, and I just read the row for the thickness I'm welding and set the wire feed and voltage dials for the wire size and shielding gas/flux core wire I'm using. Haven't found a bad setting yet. Starting the arc is easy: Just line up the gun and pull the trigger. Use shielding gas instead of flux core and it's easy to see the arc and puddle. Once you get the hang of bracing yourself so you can move smoothly, you can make some really nice looking welds and since you had someone show you how to do it, they'll be as strong as they look. Best of all, you're learning on someone else's equipment, and by the end of the class you'll have a pretty good idea of what makes a good machine. The instructor and most of the students will also have good ideas on where to buy one or maybe even know where you can get a good used machine. And they'll be able to tell you what protective gear to get, and you can try out a few different helmets to see what's comfortable.
Hope that helps...
You would think so, sjmarbu. Tried that route. But the programs at ROP and the community college are geared for folks wanting to get into welding as a career. They do not welcome hobbyists. And they are clear about that. I have looked at the Youtube videos and am willing to purchase videos as well. Its that initial leap into the pool where I'd like to have some help.
/ Total welding newie here #19
Carol,
Check your local high schools. A lot of them have adult continuing education classes and offer welding courses from the ag teachers or vo tech teachers for minimal fees. Or contact your local young farmer's organization which specialize in this type of thing. They are a valuable resource and promote ag ed and things related to ag in general. Welding is definitely one of them.
/ Total welding newie here #20
Find a steel yard and buy a bunch of cutoffs and try to weld on so you can find out how to adjust the machine befor trying on a project. I started welding when I was 12-13 years old with an old Norweld machine and some scrap, the first welding seams looked like chicken s**t but when you have burned a few hundred meters of wire you begin to get an idea of ​​how to adjust the machine for a better result.
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
Caterpillar 330/330L Excavator Parts and Service Manuals (A63117)
Caterpillar...
