B7200 lift probems
/ B7200 lift probems #1
tary
pasadena md
kubota b7200
Lost all lifting on my front bucket. how do i check the pump pressure.
Thanks
/ B7200 lift probems #2
You can put a hyd gage in a tee in the IN port of the FEL valve.
You should do a pressure and flow check.
No it has a clutch . The 3 pt hitch seems to work fine
what and where is the fel valve
What is the fel valve . where is it located
thanks
/ B7200 lift probems #7
thanks
should find it under the the FEL control lever.(front end loader)
It has clutch but is the drive system hydrostatic or a geared transmission. Both systems will have a clutch.
Have you checked the oil level? How about the quick connects, have you taken them apart and put them together? Is the joystick tight or loose and sloppy. They can wear to the point the valve doesn't get actuated.
/ B7200 lift probems #8
The FEL valve is the joystick loader valve and what you use to control the loader.
So if you have the gage, Install it in the IN port using a tee.
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
Bobcat S66 Skid Steer (A63688)
Bobcat S66 Skid...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
NEW HOLLAND 355 FEED MILL (A64277)
NEW HOLLAND 355...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
