How do you store you logging/tow chain?
/ How do you store you logging/tow chain? #141
I got 2 of these hooks from Baileys and LOVE them! Use them ALL the time. Way way better than a choker ring I was using before!
/ How do you store you logging/tow chain? #142
I have those as well. Much nicer than a typical slip hook.
/ How do you store you logging/tow chain? #143
I use a Folgers plastic container, but I suppose any brand will do. I usually have a 12 ft but it will store two twelve footers. P05-16-14_10.48[1].jpgP05-16-14_10.48.jpg
/ How do you store you logging/tow chain? #144
I use a Folgers plastic container, but I suppose any brand will do. I usually have a 12 ft but it will store two twelve footers.View attachment 375436View attachment 375437
I don't have any logging chain because I don't have any trees but I will say the empty Fogers coffee containers are the handiest thing for storing bulky and awkward items (like the chains) but also big bolts or whatever. I've got a dozen of them and all are filled with something different. If you don't have one or never saw one, take a look.
/ How do you store you logging/tow chain? #145
I have been wanting a chain storage setup on my tractor since I bought it little over a year ago. I've been working on a custom setup for the last 2 nights. Painted it tonight and will mount up tomorrow. I'll post some pics, but basically I made a mount to hold two 4"x24" PVC pipes between the left rear tire and fender. I've got 3" wheel spacers and my wheels set all the way out so there's plenty room and it's just dead space. Also, I wanted to keep the weight as clost to center and low as I could.
The RH side of my tractor has the FEL valve, mount and a Prince Hyd valve, hoses and rear remotes I installed, so there's about an extra 150# if guess on that side up high. I'd like to balance that out a bit with the chain storage (I mow slopes).
Anyway, I'll post some pics tomorrow.
/ How do you store you logging/tow chain? #146
/ How do you store you logging/tow chain? #147
Alright, finally got the pics up. Here they are.
I bought a stick of 2"x1/8"x4' angle and two sticks of 1"x1/8"x3' flat at Lowes. The rest of the metal I used was just scraps I had laying around. I didn't want to put too much $$$ into it in case it didn't work out.
I put small eye bolts in the caps to attach them to the tubes with string so I don't loose them or run over one up in the woods. The bottom end of the tubes have a 4" plastic snap-in drain grate, also from Lowes and about $2 each.
All mounted up.
I've been on the tractor all day the last two days bushogging and the setup is holding up fine so far. Caps haven't hinted at spinning loose.
/ How do you store you logging/tow chain? #148
Very creative solution.
/ How do you store you logging/tow chain? #149
Very nice work there, 9L. I have thought of doing that as well, as I also have a bunch of space between the wheels and fenders. Even went so far as thinking of a chainsaw there... but then I came to me senses, thinking of access and mud splash issues. But chains would be fine.
Doubt you will have any issues with the caps coming lose. I used a larger (6") pipe and caps as a conduit box on the roof of my service van for years, never had one come lose.
Again... nice work!
/ How do you store you logging/tow chain? #150
I have had a couple of ideas come upon me and they worked out pretty good. I was wandering through our local Peddlers Mall looking for something to use for chains (sort of an unmanned indoor flea market setting) and spotted a bicycle basket for $5. So far it works great! I'm going to modify the bottom attachment to something more stable that the current "tie-wire" and maybe even paint it JD Green.
Then I came up with the thought to cut a piece of 6" sewer pipe to fit under my tool box. Folgers coffee can lids fit on the ends just perfect. I'm contemplating an attachment method that is easily removable, just haven't settled on one yet. So far it's just wedged in place and it tends to "roll" a bit, But it sure is handy!
Both are handy for chains but the basket holds my gas and oil for my saw, gloves, Gatorade or whatever else fits and it's right there where I can reach it from the seat. This site, and the other members photos have been extremely helpful and inspiring.
/ How do you store you logging/tow chain? #151
Pretty neat ideas there garacuda!
Thanks!
/ How do you store you logging/tow chain? #153
Today at work... boss was gonna scrap an old gravely mower gas tank... we've been talkin about a chain box for the L4310 for months...
A peice of angle iron, a quick cut with the torch to shape the end a little to fit the tank...
And here we have a nice little chain can... about an hour of my time and free materials.
/ How do you store you logging/tow chain? #154
Another Dandy I'Deer FTG-05! Looks durable too! Sure looks like it ought to............do something besides hold chains though. ;-)
/ How do you store you logging/tow chain? #155
I think you meant Dieselcrawler - and I agree, another good idea!
/ How do you store you logging/tow chain? #157
Bossman, a real wiseguy, said he was going to write "Diesel Fuel Only" by the filler cap (on the side, half way down! Try filling that!) which I intentionally left visible, as well as it was the nicest looking painted side. Nearly the right color too!
I need to find some edge moulding, the top edge where I cut the end off the tank is going to slice somebodys hand (likely mine, I end up ground man most of the time when chains are used!) Even though I did my best to file/deburr the cut edge... it still sharper than is safe.
Thanks for the compliments...
/ How do you store you logging/tow chain? #158
Let us know how you solve the sharp edge issue.
/ How do you store you logging/tow chain? #159
/ How do you store you logging/tow chain? #160
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A60736)
2009 VOLVO VHD...
2014 FREIGHTLINER CASCADIA T/A 6X4 SLEEPER TRUCK TRACTOR (A59906)
2014 FREIGHTLINER...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
500BBL WHEELED...
