Dump trailer peoblem
/ Dump trailer peoblem #1
DT86
Elite Member
VA
Kubota
Can a dump trailer solenoid be replaced using a remote automotive type solenoid?
It's on a Carry On 10' trailer but can't remember the name of the power pack.
Pics to follow.
/ Dump trailer peoblem #2
Can a dump trailer solenoid be replaced using a remote automotive type solenoid? It's on a Carry On 10' trailer but can't remember the name of the power pack. Pics to follow.
The short answer is yes. I would only use this as a temporary solution until you replaced it with the manufacturer recommended unit, as the automotive solenoid may not be rated for the duty cycle or amperage etc.
/ Dump trailer peoblem #4
that appears to be one of those little hydo ready packs.. IE.. 12vdc motor ran hyd pump.
we use one on a truck with a spray bar...
bottom line.. as HHR said.. yes.. you can use a 3 wire vehicle type solenoid to do what you want. I have a ford 'firewall' mounted solenoid running the power pack on our spray bar setup.. it is repalcing hte chincey lil plastic cased one that the unit came with that failed in the first year.. this larger metal cased one has been operating at least 5 years..
/ Dump trailer peoblem #5
We once replaced a $50 solenoid in a Massey combine with a $5 one off of a 70's Ford pickup starter. The Ford starter solenoid is only a intermittent duty solenoid but it worked quite well in a continuous duty application. Give it a try as they are still not expensive.
It seems like certain year Power Strokes used the firewall mounted solenoid. That's what I had in mind to use but are they any different (HD) compared to on off a gas truck?
/ Dump trailer peoblem #7
While I have no specifics in front of me.. just looking at the practical side. most diesel pickups ( powerstrokes for sure ), use 2 batteries.. and the batteries for diesel trucks are generally larger than for gas vehicles / many diesel engines are larger than some gas.. and for the ones similar in size.. like 5.9 gas vs 5.9 diesel.. the diesel has more compression to overcome..... thus I'd IMAGINE the diesel start relay would be more HD ).
That all said with -0- specs in front of me. ;) ie.. guestimation.
... thus I'd IMAGINE the diesel start relay would be more HD ). That all said with -0- specs in front of me. ;) ie.. guestimation.
Yes, that was my line of thought also.
Thanks guys, I'm off to NAPA.
/ Dump trailer peoblem #9
The local automotive parts store carried a replacement which was around $12 when I replaced mine. Just take the old one with your so they can match the numbers.
/ Dump trailer peoblem #10
Napa usually has solenoids in stock that are for continuous duty , just specify what you want.
/ Dump trailer peoblem #11
PMSMechanic is right of course, there are both intermittent duty, usually used for starter motors and things that draw a lot of current near instantly but for short periods. Their coil winding is heavy gauge and the coil itself draws much more current than that of a continuous duty relay/contactor/solenoid. A continuous duty contactor will have a coil with finer windings and higher resistance than that of the intermittent duty contactor. Continuous duty contactors are used in golf carts etc.
Problem with using an intermittent duty relay or contactor for continuous duty is that it's coil will overheat. This will likely result in damage to the coil insulation, or may melt insulating components like contact standoffs etc. Not really a good idea.
bumper
Ok, so I came home with a solenoid for a '00s 7.3L Power Smoke.
I told them exactly what I was doing with it and that was what they came up with. Usually you're on your own with electronics after the sale but they stressed that if it didn't work to bring it back. I guess it's worth the waisted $15 to them to be able to sell the next guy the correct part the first time. IDK...
Now I'm scared to use it. So I called o'Reilly Auto and they came up with a Borg-Warner designed for continuous use. It's $25 and should be in early in the morning.
Thanks to each of you for trying to help a feller out! :thumbsup:
/ Dump trailer peoblem #14
bumper
how many times do you think the user of a dump cart is gonna run that thing up and down per use? :)
Most of them 'ready 12v hyd' units ALSO have a very, very limited duty cycle and are not rated for continous use.. I kinda have my doubts the hd starter solenoid is gonna be the bottleneck.. ;) :)
/ Dump trailer peoblem #15
Pics to follow.
From the photos, run down to Napa and get a Ford style starter solenoid. Randomly ask for one from a 1981 F150 with a 300 straight 6. You may need to mess a bit mounting it but it should not be hard to do.
/ Dump trailer peoblem #16
Yup. I should read the whole thread before blurting out a replay.
Someday. :eek:
/ Dump trailer peoblem #17
Someday. :eek:
for what' it's worth.. I agree with your post. A hd ford style solenoid liek that is very likely going to work fine...
/ Dump trailer peoblem #18
if most napa are like the one in my city.. unless you have a part number.. the counter moron can't help you.. unless he has a grey beard... if he does you MIGHT be in luck. Mine is constanly out of their 'napa know how' apparently...
NAPA, at Minden, NV never has more than 1 or 2 customers at a time. Always seems to be a minimum of 7 guys spaced evenly up and down their counter, any of whom can be counted on to be a veritable cesspool of superfluous knowledge, able to answer any question about dang near anything. Boggles the mind how they could possible turn a profit what with labor costs.
But don't try Radio Trash, their motto is, "You have questions, we have blank stares!".
bumper
/ Dump trailer peoblem #19
Today I went to a local NAPA store for a set of plug wires for an '86 Chevy pickup with a 350 V8. "None in stock we would have to order those."
/ Dump trailer peoblem #20
bumper
back when radio shack used to have a wall of small packages of electronics parts.. they had people that knew about them.. nowadays they sell phones and don't know very much..
2023 KOMATSU D51EX-24 CRAWLER DOZER (A65053)
2023 KOMATSU...
2007 JLG G6-42A 6,600lb 4x4 Rough Terrain Telehandler (A64553)
2007 JLG G6-42A...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A64556)
2019 Chevrolet...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
