BX25D Thumb installation...
/ BX25D Thumb installation... #1
Mowbizz
Lakes Region, NH
'14 Kubota BX25D
Turns out to be a major P.I.T.A. (if ya know what I mean...
Zero instructions except an exploded diagram of the whole backhoe...have to search out the little bits and parts for the thumb and the parts needed are loose in a plastic bag. Altogether, too small of a diagram for these eyes to see well... :confused:
Okay...this can't be too difficult to figure out...finally getting the parts oriented correctly, and can visualize how it installs. No mention of having to remove an existing bucket pin
and replace with the retro-fitted one to hold the bottom end of the thumb...okay..now I see it!
Start pinning the parts together and find that the main pin for the top of the thumb (that's supposed to fit into the new BX25D welded on thumb bracket) and the pin won't even start to go into either those holes nor the one on the part that installs there...okay...what am I doing wrong?? Going over the tiny diagram again...hmmm...looks correct to me!!??
So I decide the pin is too large to enter the holes or the holes are too small for the pin...call the dealer and the guy says "oh, you need to hone out all the holes first."
Okay...figured it was something stupid like this...after all, the machine sits for who knows how long in the dealer's lot with the "holes" exposed to the weather. Make phone calls to several hardware and auto parts stores and Auto Zone has a drill type brake cylinder hone that will fit into the 1 inch hole...drive an hour round trip and return with my honing booty put it in the drill and commence to hone...
Never honed before so I don't know if I'm doing it right...oil? No oil? Anyway after an hour of honing just the one hole on the part that hangs from that welded on bracket and the pin still won't go in.
Decide the hone is a cheap chinese product (for $19.00 mind you) but it says "made in USA" on it...hmmm... Well I guess it's USA made junk.
Off to the basement for my Dremel kit. Happen to have a few of those tiny sanding drums and try one of these in the hole...removing some metal now...this should work! Pin still won't go in.
Now I'm looking at the pin to see if it has any burrs or imperfections on it. Nothing that I can see with the naked eye...put pin in vise and start using the Dremel on it...okay...forming a nice taper on the end and smoothing the
area around the hole drilled through the pin (where a small bolt secures it in place when installed) Steel wool the pin to smooth it out a bit and voila...one end of the pin can now start into the hole but only part way.
About another two hours of sanding, dremeling, honing and steel wooling both the hole and the pin and the pin now almost goes through all the way! Yay!
Good to go with the pin and the part...now back outside to start the whole process again with the holes on the welded on thumb bracket...another two hours of the same routine and I FINALLY can hang that damned part on the welded on thumb bracket! Yay. The rest must be cake! Find the correct orientation of that part because there are no instructions and there seems to be some interference with the part and the backhoe boom...figure that out and now to replace the bucket pin with the new pin and retainers. Old pin comes out slicker than snot...okay...now to pin the thumb on at the bucket end and not as easy as it looks as there are more things to line up than my two hands can handle...Call the GF to come outside...she jumps out of the shower and puts ona robe and comes to help...I give her some rubber gloves because I have grease smeared all over creation trying to line up the pin holes
and after a few minutes we come up with the right combination of swinging and lining up the holes and the pin goes in! Yay.
The rest of the install is just installing the new pin retainers. No problemo. I now have a greasy thumb installed!
I gotta tell ya...some of the folks on here that create these custom parts get all my respect. If the lowly mechanical thumb took me this long to install...I have to wonder about my abilities and tool collection...:laughing:
But...I did it with will and determination and a few hand tools and a lot of swearing...no thanks to Kubota and their seemingly, poor instructions and parts fit, etc.
I'll take pics tomorrow...:)
/ BX25D Thumb installation... #2
Nice work can't wait to see the pics. Btw The big ones are easier
Thanks! I believe ANYTHING would have been easier than this one! I should mention that on my last BX(24) I installed a Bro-Tek thumb and it went on in a few easy, minutes. This one is a part of my BX25D now and the install is a good lesson in perseverence.
/ BX25D Thumb installation... #4
Bizz, I installed my thumb a few weeks ago and everything fit well. I agree the instructions could of been better and a third hand would of been nice, but now where near the difficulty you had.
Hmmm...well it just goes to show that there are some differences in either the parts or the holes in the bracket! Glad you had an easy time with it!
Re: BX25D Thumb installation...pics
Here's the little bugger that gave me fits with one pin's FIT in particular...the topmost pin is the culprit...
Hope this description helps someone else who's going to tackle this same install! :laughing:
/ BX25D Thumb installation... #7
After reading Mow's story, I'm sure glad that I never installed a thumb on my BX-25.
In my honest opinion, this should never have been as difficult as it was. Bad luck on my part, I'm thinking...
/ BX25D Thumb installation... #9
It sounds like something was wrong with your kit like one of the bosses wasn't square when they welded it or the pin was machined the wrong diameter. I can't believe all the trouble you had to go through is normal
You are correct! I believe "all of the above" was wrong with my kit!
/ BX25D Thumb installation... #11
OK, now that you have the mechanical thumb, time to upgrade to hydraulic thumb. You wont believe the difference it makes in useabilility.
Love one but this will have to do unless someone wants to come over and install one for me!:D
/ BX25D Thumb installation... #13
Have a B2620 with BH. Done some trading with Barlows and I asked that a thumb for my BH be included and it was. Thumb has been in the box for a couple of weeks so I finally opened the box on it's side and let the parts fall out or some of them have. Now tractor is at my other location. Was hoping for an easy install but now you have my sphincter muscle getting a bit tight.:D
Oooh...too much info...lol All I can say is good luck with your install!! :D
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63118)
2023 Kubota L3560...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
Komatsu D39 PX Crawler Dozer (A61166)
Komatsu D39 PX...
20ft trailer (A61569)
2014 Wacker Neuson ST45 Compact Track Loader Skid Steer (A61567)
2014 Wacker Neuson...
2022 CORMIDI C85 STAND-ON MINI DUMPER (A62129)
2022 CORMIDI C85...
