Kioti broken steering sector shaft
/ Kioti broken steering sector shaft #1
DOUGAB
SYRACUSE,NY
86 KIOTI LB2204
I'm new and need help! I broke the steering sector on my Kioti LB2204 and can't get a new one. I have heard that some of the early '80's Kubota's will work but don't know which ones. A point in the right direction would be great.
/ Kioti broken steering sector shaft #3
Hi, I have the same Kioti machine with broken steering. Did you ever find a fix for yours? Thanks for your help!
Hey. Sorry about your tractor but I do have the numbers for you. The sector shaft is a Sparex brand. S.66828 is the part number and that replaces SBA334130041. You will need to find a dealer and you should also buy some shims for the cap. The shaft fits perfect but the splined end is different. I bought one off the internet (used) but I think it comes off a Yanmar. (it was a pale green) The only other problem I had was the bolt that slides in the end for adjusting. I bought a metric bolt that fit the nut and chucked it in a drill press and ground the head to a circle that fit the end of the sector. Hope this will help!
/ Kioti broken steering sector shaft #5
Thanks for your quick reply! And also the very helpful information. I will check it out and let you know how it goes.
/ Kioti broken steering sector shaft #6
I have the exact same problem. Please ntify me if you get an answer and I will do the same for you
/ Kioti broken steering sector shaft #7
Hi, My tractor is an 86 LB2044. So it may be a little different....The information I got from DOUGAB helped me find the parts I needed and get it working. My sector gear shaft was fine. I needed the steering shaft Nut and a Ball and Tube kit due to water getting into the steering case and freezing.
The numbers that fit mine are on the Sparex web site and were listed for Mitsubishi/Satoh compact tractors: Steering sector gear: S.66828 Steering shaft nut: S.70583 Steering Ball & Tube kit: S.70582
The measurements of the parts are listed on the site so you can compare them to yours before ordering. I got a good deal on my parts ordering them on-line from Reliable aftermarket parts, inc.
Good luck getting it going!
/ Kioti broken steering sector shaft #8
Just wanted to send you a quick thanks for your help. Your part information lead me in the right direction. Its all back together and working great.
Thanks!
/ Kioti broken steering sector shaft #9
Sorry I gave you incorrect info. My tractor model is an LB2204.
/ Kioti broken steering sector shaft #10
Doug,
Dragging up an old thread here as my shaft has broke for the second time in about 300 hours. If splines are different how did you work around this short of buying a matching steering arm ?
Brad
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2021 CATERPILLAR 289D3 SKID STEER (A65053)
2021 CATERPILLAR...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
