power barrow
/ power barrow #1
Sheetanshu
Mumbai, maha
None
Hi
I recently came across power barrows specifically the muck truck .I really liked how it looks and it's capabilities in the videos uploaded .Has anyone used it for agricultural purposes and how is it overall ,specially on slopes ?
/ power barrow #2
They are good, carry plenty of weight but you have to be careful with side slopes as they are pretty top heavy once you load it up. I have had mine for 5 years but really havent used it that much. Mines been reliable and they are easy to use.
/ power barrow #3
I looked into several power barrow options and settled on a 2 wheel tractor by Grillo. They are all shaft drive and can take several attachments. With steering brakes it is very mobile.
The website is earthtoolsbcs.com
I attached a photo of my unit.
Check out the 2 wheel tractor forum on TBN
/ power barrow #4
I think that one's under powered for that barrow. Good grief, looks like enough motor to run a barrow 5 times that size.
/ power barrow #5
It's an 11hp. The barrow is a standard size, I want to eventually replace it with a large custom barrow.
/ power barrow #6
Here is mine. :D
And for larger loads, an old garden cart with the wheels removed.
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
Husky 5000Watt Portable Gasoline Generator (A64553)
Husky 5000Watt...
2024 JOHN DEERE...
