Fire Pit Metal Insert
/ Fire Pit Metal Insert #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I built a fire pit and now need a metal insert for holding the wood while it burns. I have a plan for the insert but have a question about painting it. I looked at high temperature Rustoleum and the directions on the can says that the paint should not come in direct contact with a flame. Well that's no good because that's exactly what will happen. Anyone ever used a high temperature paint for a similar application? Is there any other kind of paint that will work. I think it needs to be painted otherwise it will just rust away in the outside environment it will be in.
/ Fire Pit Metal Insert #3
/ Fire Pit Metal Insert #4
Paint will not work. Around here the materials of choice are a section of heavy steel pipe or a truck rim.
The idea being that the heavier steel of these items will make them last.
/ Fire Pit Metal Insert #5
Up here people will go to a machine shop with a large slip roller and have one rolled out of some thick steel...how thick depends on the shop and how tall you want the ring. I know of one that is probably 3/16" steel, 8-10" tall, rolled by a local amish shop...
Heavy pipe is a great option also...
Joe
/ Fire Pit Metal Insert #6
On plain steel the fire will soon remove paint.
/ Fire Pit Metal Insert #7
Just throw a big truck rim in the hole and be done with it. No paint needed. Any freight company or big truck tire shop would have one or two scrap rims laying around that you could probably get for a song.
/ Fire Pit Metal Insert #9
Agreed. I have something similar to this:
The one I have is 38" in diameter and has several spiral flutes on the inside (used for adjustable width, I believe). It's old, rusted beyond it's purpose in life, and absolutely perfect for a fire pit.
/ Fire Pit Metal Insert #10
I have seen people looking for 38" rims and spending a lot of time patching holes in ones like you describe. The power adjust rims in 38" bring a pretty penny for most of the tractors I know of. Sell it and find a truck rim would be my suggestion.
David from jax
/ Fire Pit Metal Insert #11
A few more minutes worth of searching yields the proper name for my pit ring... a "spinout" wheel, like this:
/ Fire Pit Metal Insert #12
oh come on. i have a rolled 1/8" fire ring that my wife purchased from cabelas years and years ago. its painted with plain old rustoleum flat black over a coat of primer. i have had to touch it up a few times over the years....maybe 2 times in 8-9 years. the paint holds up just fine. i didnt even use hot engine paint....just used regular rustoleum.
and i burn some hot fires. will be having another this weekend for my BBQ of chicken wings and tri tips.
/ Fire Pit Metal Insert #14
A friend of mine uses an old washing machine drum - it's kinda deep, but otherwise it works great. All the little holes let it breath well.
/ Fire Pit Metal Insert #15
An old tractor rim that has been rusted out due to a salt type mix to keep the water from freezing then leaked out due to a puncture in the tube, works nicely.
If you want it to look pretty use fire bricks.
/ Fire Pit Metal Insert #16
yep, big tractor rims are great!
/ Fire Pit Metal Insert #17
/ Fire Pit Metal Insert #18
I used a 36 inch tractor rim for awhile but it was not tall enough for the amount of wind we have here. I sold it and built one out of landscaping edging.
/ Fire Pit Metal Insert #19
In the Houston, Texas area we have literally 100's of oilfield pipeline company's here on the Ship channel. I called one a few years back and the salesman told me they had scrap pipe ends cut off transmission lines and I could have one for the cost of the ring at scrap price. When I arrived I was given a 4 foot diameter pipe one foot tall an 1" thick for free! When the fork lift placed it in the back of my truck it lowered the rear bumper about 10 inches. A thousand years from now some archeologist will wonder what it was used for as my family won't wear this thing out for a dozen generations. No paint, just fire!
/ Fire Pit Metal Insert #20
free? 1" DANG... can't beat that!
PORTAPOTTY (A67714)
PORTAPOTTY (A67714)
2015 PETERBILT 579 (A67714)
2015 PETERBILT 579...
2020 KUBOTA SVL75-2 TRACK LOADER (A59914)
2020 KUBOTA...
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer w/ 7 Ton Gooseneck Trailer (A66734)
2023 JCB 3TS8T...
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
2013 Ford F-150 Crew Cab Pickup Truck (A66736)
2013 Ford F-150...
