grease your balls or not
/ grease your balls or not #41
Because they end up banging up my vehicles. Had it happen to my BMW and last F150. Plus it's a shin banger.
Chris
You shouldn't walk that close to somebody else's vehicle anyway!
For me, it depends how soon I'm going to use it again! This is the first pickup I haven't had mine bolted in and the threads peened on the bolt. ~~ grnspot
/ grease your balls or not #42
Now the ball I'll be using is from 1964 so I don't think a rubber will be necessary but I think I may need to lube it up for this virgin trailer I'm about to pay for.
Be careful. A ball as old as yours will shrink with time and could slip out if put to much force.
/ grease your balls or not #43
I disagree. They are designed to come out after use.
Chris
/ grease your balls or not #44
Agreed. I tow a lot. I use my boat 2-3 times a week in summer. I use a bolt with a lock nut to make my hitch more or less permanent. And yes I grease my ball.
/ grease your balls or not #45
I tow just about every day and take mine out as soon as done. Not a big deal.
Chris
/ grease your balls or not #46
Chris
This one is for you Chris. I saw this yesterday, tried to snap a pick, but couldn't get to the phone fast enough. I came up behind a Chevy Colorado yesterday at a red light. I saw it, but wasn't paying super close attention, but I was stopping far enough back. Then all of a sudden I saw something. This guy had a 2" tube sticking out of his hitch that stuck out 4'. Stuck straight out almost like a hay spear. I followed him in to Menards and then he proceeded to go head at another vehicle so he could back into one of the loading spots up in front of the building so his 4' extension could hang out over the sidewalk. I've never seen anything like it - maybe part of a bike rack, but missing the part that made it so you could see it. Had I not been paying close enough attention or whatever, that could have been real bad.
/ grease your balls or not #47
Big difference between a 1' or less drawbar & what you're talking about! ~~ grnspot
/ grease your balls or not #49
Seeing this was at menards & a small truck, I'm going to guess it was a load extender. The guy was likely going to haul a long piece of lumber or pipe home.
/ grease your balls or not #50
If it were to be a load extender, there should have been a piece sticking up to catch the load and a least a red flag on it. The 2" straight tube sticking out was really hard to see.
/ grease your balls or not #52
Have had hitches all my life, and most of the time they were left in.
I cannot think of one time I have hit my shin on one.
/ grease your balls or not #53
Some teen driving an Oldsmobile hit the back of my Silverado... I had just unhitched the trailer and wanted to top off the truck fuel tank.
The ball mount took all the impact and not a scratch on my bumper... the Olds had a trailer ball pushed all the way into the radiator and that was against the fan...
Just don't see a downside here.
:laughing::thumbsup: I Love It- that will teach em to text and (drive) You are right - NO downside...
/ grease your balls or not #55
This is drifting off-topic from greased balls, but I wondered if all you folks who leave the hitch in the receiver all the time also have a locking pin to make it harder for somebody to steal your hitch.
/ grease your balls or not #56
Leave your receiver in for more than a month here and it's a permanent part of the truck.
/ grease your balls or not #57
Yes, I have locking pin. I tow 90% of the time I use the truck, no use in removing it, I live in the country anyway, if I am in town I am working and hauling trailer with equipment.
/ grease your balls or not #58
Yes I do. Make it harder to steal whatever trailer is on it more so than the ball mount itself.
I have accumulated more than I will ever wear out or loose in a lifetime.
/ grease your balls or not #59
/ grease your balls or not #60
I did. It gummed up/corroded enough that the key wont's turn now. I want to pull the hitch, but will have to cut the hardened locking pin. We tow frequently, so I had just left it in there.
How best to cut that pin? Sawzall, or?
3/8" Quick Attach Blank Plate (A66408)
3/8" Quick Attach...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
OVERHEAD PROJECTOR, HP PRINTER, (2) MONITORS (A64276)
OVERHEAD...
90in. Work Bench (A65640)
90in. Work Bench...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
