Tractor "Tiers"
/ Tractor "Tiers" #1
Hiltz
Gold Member
Michigan
JD 790
I see on here from time to time people mentioning "Tier 3" , "Tier 4 " tractors. Could someone explain that one to me. Was there a 1 and 2 also? Thanks
/ Tractor "Tiers" #2
The Tiers refer to the pollution control levels the tractors must meet. With tier 4 final being the current set of specifications of the emissions of the tractors. This has been going on for many years, and all new 2014 models over 25 horsepower must meet the tier 4 final spec.
/ Tractor "Tiers" #3
tractor dot com has a pretty good article on the emission tier progression.
/ Tractor "Tiers"
Thanks guys
/ Tractor "Tiers" #5
I would think that "Tier 4" would cause the value of, prior to 2014, used, 4-wheel drive, tractors to skyrocket. One things for sure, they would give you significantly more hp per the dollar. I am so glad that I bought my "new one" back in 2005.
/ Tractor "Tiers" #6
As I understand there are only two options for tier 4, one you put some kind of fluid in that the tractor uses....it is about the same price as fuel. The other option is some kind of EGR/scrubber....and that will need to be replaced after X hours....and that is not cheap.
My question is....knowing the people that buy tractors are the....cough....handy with tools....cough type.
What happens if you don't put in the fluid....or put in some other type of fluid.
What happens if you bypass the EGR system.
Wonder if the greenies ever thought about that....or the people that design the systems.
You know it is going to happen.
/ Tractor "Tiers" #7
SCR tech used to pass tier 4B (tier 4 final) specs allows the tractor company to focus on building the most powerful, efficient engines. Tier 4A (tier 4 interim) allowed tractor companies to use an EGR valve be added to existing engine designs and pass emissions but at the cost of efficiency. Thus one of the big pushes by tier 4B compliant OEMs is advertising the lower operating costs of running their brand because of the more efficient tier 4B engines.
The reason everybody doesn't have tier 4 yet comes down to the cost and time to develop new engine programs.
Massey's advertising CVT transmissions and tier 4B is where the world of tractors seems to be heading.
/ Tractor "Tiers" #8
So far it doesn't seem that any of the size tractors that most of us us the CUT size use the DEF (Deisel Exhaust Fluid). So given that the equipment is already in place on these new Tier 4 tractors and paid for by the owner, I don't think many of the owners are going to try to disassemble the equipment or bypass it in any way. The new engines in these tractors do not seem to be lacking for power and have the added benefit of lower exhaust emissions. The only downside seems to be the added cost.
/ Tractor "Tiers" #9
I found a video that explains exactly how SCR works that is interesting.
/ Tractor "Tiers" #10
I agree.
Remember, the Tier 4 mandate has been in place for several years now for on road equipment. So, there is millions of miles of experience with the technologies in use.
Yes, all of this stuff can be bypassed or disabled. There is an aftermarket to do so. But any of the diesel forums I've visited don't indicate to me a clear advantage for doing so and most of these "kits" seem cost prohibitive for a diesel engine in a CUT.
Service of the DPF is many hours down the road. I some case's I've seen 5000 hours or more. I'll probably be long gone before I get 5000 hours on my tractor.:laughing:
I am glad I've got a Tier 3 tractor. But, if I were shopping tractors right now, I'd buy the tractor I liked and fit my budget without regard if it was Tier 3 or 4.
/ Tractor "Tiers" #11
teir 4 has made all teir 3 tractorup in price matter their age.ive seen 10yr old m6800s selling for what they did new.an used 7040s doing the samething.
/ Tractor "Tiers" #12
That video was pretty nice propaganda. But I am sure there are down sides to all this. I don't have a problem with this technology, I also highly doubt that the system will last the lifetime of the machine, 5000 hours it what they tell us. But computerized exhaust monitoring with up stream and down stream sensors sounds like a great deal to go wrong on a machine like a tractor working in very dusty areas.
I really hope this works, but I would not be shocked to see a long list of problems related to this technology, not to even go into the price of all things produced with machines using diesel power to go up as well.
/ Tractor "Tiers" #13
Agreed. I'd love to know the prices of these various sensors at the parts counter of a dealer. Much like O2 sensors for gasoline fuel injection engines, I suspect they are not going to be cheap, and will probably be subject to periodic failure.
/ Tractor "Tiers" #14
The warranty requirement for all emissions related components is 5 years 3,000 hours for tractors over 25 HP so it may be a few years before customers need to buy any of the components. The only on-line prices I found in a quick search are $300 - $690 to clean a DPF depending on the condition. The only tractor we have with a DPF so far is a Kubota M135GX and its service recommendation is to have the DPF cleaned every 3,000 hours.
I assume CNH had some difficulty getting their SCR into production on tractors with engines in the 100 - 175 HP range, specifically the T6 series New Holland. One of my neighbors had one on order for last year but when the dealer couldn't get any from the factory until July, the neighbor took a Kubota M100GX instead - it was already on the dealer's lot. A couple of my neighbors got T6 New Hollands this year. It will be interesting to compare notes in the fall.
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
(APPROX.100) UNUSED KJ 10' HD GALVALUME STEEL (A62131)
(APPROX.100)...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
UNUSED WOLVERINE QMP1-16-6T QUICK ATTACH PLATE (A62131)
UNUSED WOLVERINE...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
